What Detailing / Car Care Products Have You Bought / Ordered Today?
Aha, but the accounts dept would say that the glass had be made too large in the first place ;-) ;-) However you are correct in that every little helps.
Thanks for your support though, getting stronger every day now :) :)
Reactions: Bristle Hound, Jassyo06, Jimbob76 and 1 other person
So I’m enjoying m’new Karcher K4 (and the 10m extension hose I got from Amazon is a god-send - gets right around the car without having to pick up and move the base unit at all). BUT, one thing that’s been bugging me compared to my old Nilfisk is the quick lock hose is ‘locked’ in one position when connected to the hose gun (i.e. it doesn’t swivel in’t gun’s socket). I’m finding this means the hose gets tangled/coiled up pretty easily. So I’m having to stop and re-straighten the hose a few times. Annoying.
Might have found a solution with some other added benefits though, so order placed...
D9E954C3 6259 423D 854A 3B06E0F2822D
010532FD 2A4E 472F AD17 F33B32F8E0D8
It’s a ‘shorty’ gun, and the 3 different quick fit ‘stubby’ nozzles give different widths of attack. No more need for 3 feet of Karcher gun and lance - this is just 20cm(ish) of compact one handed alternative (leaving other hand to hold hose and keep away from your bodywork). Comes with a quick fit adaptor for my Autobrite snow foam lance, so that will connect directly to the shorty gun as well. Looking forward to trying this - will report back. Didn’t think it was a bad price (used the forum discount code ASNET for 10%) :thumbs up:
Reactions: Jassyo06 and NevMan
This looks very interesting, are the different nozzles different fan sprays? Interested to see how you find them, been meaning to order that 10m hose you mentioned for the same reasons you said, the standard one means lugging the pressure washer around the car
Reactions: Jimbob76 and NevMan
Hmm, VERY interesting mate, and know what you mean about current gun...let us know how it goes
Reactions: Jimbob76
Longer hose is a godsend mate, especially the rubber one so not inflexible like karcher one.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/202111328060
Reactions: V6_Man, Jimbob76 and Adam14
Reactions: NevMan
Aye, 3x different quick fit nozzles for 3 degrees of spray fan - I like the idea of 40 degree fan for ‘sweeping’ off roof, bonnet, doors etc. And narrow fan (without 3 feet of gun and lance to contend with, for wheel arches, getting under side skirts etc). So small you can keep the spare nozzies in yer pocket and just swap ‘em over quick sharp. If it’s crap I’ll be sending it back, but hopeful...
Reactions: NevMan and Adam14
Hi, could you send me a link to the 10m extension house, and the price please...:thumbs up:
Look at eBay for qwashers. They do rubber hoses so nice and flexible. About £30 or so I recall
Just got these in. Cait wait to use them. £22 from eBay. Came with another sprayer and 1 micro fibre cloth.
A7 3.0tdi 272 Black Edition Mythos Black Tech pack
Reactions: NevMan, Adam14 and V6_Man
Best cleaner and sealant I've ever used, you won't be disappointed
Reactions: Bishop187
Bought this and applied it to the front screen yesterday, still my go to windscreen ceramic coating
4CCC7A43 406E 41DA AF99 1A46D9B22668
Reactions: NevMan
Does anyone know what's in the KKD Citrus magic? As I said before they've sent me this instead of the AW cleanliness and used it firstly for my work's van through the foam lance but with limited success. As the weather was perfect yesterday I've decided to give it a go on my car but instead on 1:100 as stated on the bottle I've done maybe 1:10 in the sprayer. Impressed with the results but now after my drive has dried up I can see it had discolorated the asphalt where it has dripped from the car's body. Also, yesterday when applying the QD I've noticed a couple of clear coat scratches and a few very small patches which become darker so hence very visible on white paint. Could it be that I've 'burned' the paint? What makes me think I didn't is that the wax was definitely still there after rinsing and also I haven't left it to dwell as in, as soon as I've finished spraying it I've started rinsing.
Apart from these concerns I'm happy on how it worked in this concentration, the bug splats were just washing off after this.
Thanks all.
Thanks all.
A dilution rate for this stuff ain't 1:100 mate through a foam lance its 200mls per litre so its 1:4
Reactions: DanZ
You'll need to clay your windscreen firstly then do a couple of applications of glass specific polish if you dont yer in for a lot hassle with wiper rudder and heavy smearing
Think I will stick with H2Go then
A dilution rate for this stuff ain't 1:100 mate through a foam lance its 200mls per litre so it's 1:4
I think I have the old version of this stuff and deffo it says 1;100 on the bottle... I've applied with the hand sprayer at about 1:10 so not sure if I've done something bad... it scares me seeing the drive with the discoloration, I'm thinking if it did that to the asphalt... anyway, I can't take that back.
Thanks.
Thanks.
Your just been paranoid mate kkd are a reputable company your dilution ratio through a hand pump sprayer is far too much
Screenshot 20190625 063806 Chrome
Reactions: DanZ and NevMan
All over it mate, my fourth time using it now love it
Reactions: NevMan
Have only used AngelWax H2Go. How easy is this to apply and how long does it last?
Very easy mate, prep the windscreen as Jason said by claying it, then use a glass polish to finalise this step. Quick clean again with Gyeon glass cleaner and then apply three coats leaving 5 mins between the coats and allow 15 mins to dry. Buff off with the c2 and viola mate
Reactions: NevMan
Little top up order:
Trying WetCoat for 1st time, but should go well with my Q2 Pure Coating
Reactions: SPIKE_ and Jassyo06
Thanks mate, pretty straight forward, but what is the longevity like?
How comes you need a Gyeon drying towel again mate? Thought you'd ordered one the other week unless I'm mixing people up which is highly possible.
Reactions: NevMan
Wet coat application Erm....by hand ie wet microfiber pad? not a Mitt, pads are far better
Reactions: V6_Man and NevMan
Could have been me, want another one, as only a tenner, and often wash both cars at the same time or one after the other, so like to rotate and use fresh towels for each. Will now have 2 x Gyeon, and have 2 x CG Wooly Mammoth. And then other older drying towels I use for sills/door jams etc
Reactions: Adam14
Ok, so you would recommend M/F pad to apply? To wet car I gather?
Wetcoat is the same as Hydro2. I would apply it to the wet car and jet wash then by hand using a pad. I have always sprayed Hydro2 on a wet car and then washed it. Drying afterwards becomes a piece-a-cake!
If you are really feeling the 'urge to apply something by hand' I'd rather it is Reload/Cure
Aye pads are far better for a neater application,mitts naw to messy too big
I only use wet coat on my alloys now ....much prefer a wax over wet coat now as beading is far more refined...and less of it....
Applying/Rinsing it off on a wet car leaves spotting on glass and the paint mate l have noticed it all the time on avrils car
You mean spotting with wet coat? I have not used Wetcoat but never had any issues with Hydro2 on either of the cars.
Your loving your Gyeon! Is Tire express your new fav tire dressing?? looking to try something new in the next month or so, and looking at my options.
Reactions: NevMan
