lol so obviously people have differing opinions on this, fair enough, everyone is entitled to their opinion.
However instead of spit balling scenarios and differing opinions I decided to actually ask the people that deal with RTC’s on their opinion on this. Now bare in mind they’re not car people so water meth isn’t something they know much about.
“We go through a process of ripping and stripping prior to cutting into a car to expose those hazards that might be a hazard to us and occupants. There is a chance we could expose the Methanol Water kit and therefore identifying hazard stickers attached to the Methanol tank would be very useful.”
In regards to tanks that are leaking:
“If the Methanol tank is cracked/leaking we can either plug the crack, syphon or decant into another container. Again, it would be prudent to have warning stickers on the tank so we know what we are dealing with. I guess some people may go higher percentages on the Methanol in the mix, which then does start becoming a problem.”
“We have had incidents where following the RTC the fuel injection pump continues to run, therefore supplying fuel to the engine either causing a higher risk of ignition or fuelling an existing fire.
So if there is a risk that the Methanol Water Kit could do the same, that would be beneficial for us to know to help us deal with it. It would be prudent for the driver to know that the kit will cut out with the rest of the electrics. With so many stored energy cells, engine management systems and reams of wiring looms it might not be as simple as you think.
So basically when it comes down to it, we can deal with it: but it would be really good for us to know with identification stickers on both the tank and preferably externally.”
I have no idea if most water meth kits have a fail safe built in so the bit about the pump still providing meth if it jammed or something is obviously not applicable if they do. The point was also raised about a thing about the fire service wanting cars running a split LPG/petrol having warning stickers after some firefighters were injured after attending what they thought was a normal car fire.
So there you go, seems the professionals that know what they’re doing would prefer to know that meth is on board. Who would have thought it?
. Feel free to do with your car what you wish by the way lol.
