So I've recently been getting reduced oil pressure warning (brown plug near oil filter) on my newly-ish built 83mm piston engine with roughly 7k miles. Really started happening after I changed from 0w40 to now 10w40. This ideally should not make a difference. Also happens when the car is at operating temp (over 180°F+ only).
Was reading on previous gen ea888 engines the pcv could cause this and was a recall. Currently have CTS on the car so going to put stock back on just in case.
I've also changed the actual brown pressure sensor too, oil is at normal levels. Is there anything else anyone would suggest before I try and tear down the engine for the worst case scenario of maybe rod bearings? Only thing is machine shop spec'd all bearings... Just at a loss of what to look for next - been riddled with issues, mainly all software related.
Is there basic settings that needed to be performed after new engine installed as I'm not sure the shop did it since I have a strong angle sensor issues when I picked it up originally.
Sent from my Pixel 2 XL using Tapatalk
