Not another Nogaro!!!
Pics have popped up!
E4E1F958 6434 4D56 8F5D 16841AB65EAC
- on the drive down to the track. A great mix of cars!
C9736A19 36F5 4861 92B8 20FAF20B9AD0
- here we go
A68FA31B F277 4C75 83B9 AAF2CE83CBD6
- emergency pit stop to re attach hose
E1F3A709 2DBA 4CD5 9FA2 A1A1E1799B31
- back in action and taking the hairpin before the straight
Reactions: ToughlilT
and some live action drive by's
lucky someone was filming otherwise I would've cried a litle if i didn't get any pic/vids of Noggie on track.
TBH i'm just relieved she came out the other end still being able to drive + an 8 hr drive back home after the biggest caning ever!
Reactions: hydro s3
I swear I’ve done these ****** things at least 3 times! Hahaha
5AD1FC27 220B 4EC7 A49F 8E45F4AAA738
Not sure if this will help anything but...
B2E1FABE B4C5 431B 86DD CB06C15220E6
Have opened up both sides. Could possibly do a cold air feed from them. Have seen it on these forums before.
Reactions: S3AMJ
I guess i don't belong to these forums anymore...
This has been sitting around for a while now and as i've gone to move interstate, a change of plans have come along with Noggie.
P1330013
As you can see it looks like a palava! All of these unfamiliar things going on with wiring, plugs and many components i'm looking at thinking "what is this?" and "gawd what a mess"
P1330014
P1330015
So out come some tools to start pulling this little beast apart
P1330016
- managed to get these off without breaking anything
P1330017
- labelling as i go
P1330018
- releasing the serpentine belt. I used a rear CV to diff flange bolt - perfect length!
P1330019
- off it comes. Had to make note of it's routing too.
P1330021
Serp Belt few colors
- after many bolts on the front of the head, side and back - the convoluted inlet manifold can come off.
P1330024
- hidden underneath are the injectors, proper access to the coilpacks and fuel rail. Without the inlet manifold removed it's quite difficult to remove the coilpacks without a tool. Now i can just pull them out by hand.
P1330025
- the angle of these! :blink:
P1330032
P1330033
P1330034
- these were looking a tad crusty
P1330035
- Now that i'd removed the spark plugs it makes it much easier to turn the engine by hand. Finding the TDC marks and lining them up. 27mm socket to turn the dampener bolt! LOL
P1330039
- reference shot of the back of the engine
P1330040
- cam cover off to be met with a slightly brown interior
P1330045
- you need to lock the cams in place before doing timing work. I didn't want to pay $150 for the official tool so i used some off cuts that i had from making my oil cooler bracket, stacked them up and they fit perfect!
P1330046
- more reference pics and marking with single or double lines to make sure plugs go back in the right spot
P1330048
- top and bottom timing chain covers off. The crank and flywheel are mated together with 10 bolts!!! They're definitely not going to to anywhere.
P1330049 P1330051
- these bits needed a bit of a scrub
P1330052 P1330053
P1330148 P1330149
- turning my attention to the gearbox side of things. You can see why you need the VR clutch housing. The Gear housing is interchangeable. The bevel box is also slightly different. Notice the shaved edge on the VR part vs the 1.8t. The bracket is also different. CV heatshield is the same. I opened these up to swap in my 1 piece selector forks.
P1330056 P1330061
P1330062 P1330063
P1330058 P1330057
P1330060
- turning towards the wiring loom now, count 'em! 6 coilpack plugs. wooo!
P1330131
- This was the not so fun part. Where the 1.8t has TWO lambda plugs. the VR6 has 4. They need to fit into the tiniest gab in between the brake fluid reservoir and the chassis. FML.
P1330132 P1330133
P1330134 P1330135 P1330137
- it's doable, just takes a bit of fiddling around
- since it was out and very easily accessible i decided to refresh the timing gear: chains, guides and the two tensioners
P1330138
- comparing the wear on the engine's original guides vs. new. You can see the tracks that have been worn but it doesn't look too bad.
P1330139 P1330140
P1330143 P1330142
P1330144
- all done and fitted! Surprisingly "easy" because of all the reference marks and colours chain links that you've got to work with.
P1330145
- refreshing the seals on the upper timing chain cover. Just a simple case of push out and push in.
P1330146
- i was impressed by how "idiot proof" gaskets are. They are all notched so you know exactly which way to put them. The cylinder cover bolts are also held in by the gasket as you remove it. No more losing these!
P1330150 P1330152
... and i've run out of photo upload allowance!
TBC
Reactions: killfame, Tj 0785, hydro s3 and 1 other person
- refreshing general maintenance items. Thermostat, oil filter and spark plugs (which are damn expensive). Again you gotta use a big *** socket to access the oil filter.
P1330154 P1330155
P1330157 P1330156
P1330153
- to keep things simple i am using the VR6 oem downpipe and cats. Just letting them rest here for now. The 1.8t shifter cable bracket also needs changing to the VR6 bracket.
P1330158
P1330162
- clutch refresh. The clutch on the 120xxxkm motor actually didn't look too bad but better to be safe than sorry. Not too expensive either (gotta love AfterPay)
P1330163 P1330164 P1330165 P1330166
- putting the oil filter housing back on i noticed there's a spare bung on it. So i'm able to keep my oil pressure gauge functionality. *i actually didn't leave it like this as it stuck out too far and the plug for the oil pressure sensor didn't reach. The way have it installed is oil pressure warning sensor in OEM placement and the oil pressure gauge sender coming straight from the oil filter housing. Work's great!
P1330167 P1330181 P1330168 P1330182
- stupid me cut the pre cat o2 sensors from their plugs... EEEEEEDIOT!
P1330183
- Gearbox on. I've figured out a really nice way to do this one manned with the engine on a pallet and offering the gearbox up to it on the trolley jack. Works every time! The angle of the gearbox mounting means it needs to lean toward the front of the car. Once i used this hammer as leverage i was able to match up the main input shaft to the clutch giving me the brake fluid squirt on the chest. My main indication that i've got things lined up :butterfly:
P1330169 P1330170
- these are my 3 reference points to swing the engine into the bay. Line these up along with engine/gearbox mount points and everything moves forward nicely. I did remove the ball joint on the gearbox side due to me rolling the engine in a little too far to that side. Removing the ball joint allowed me to manipulate the driveshaft so the gearbox could move back a little bit more than i could start all the driveshaft bolts by hand.
P1330179 P1330178 P1330180
- the vacuum lines took a little bit of nutting out to get right. Basically need to use the VR's vacuum and coolant lines and then get creative with the brake booster piping.
P1330186 P1330191
P1330190
P1330193
- now this is where things start getting tight. I noticed the A/C pulley was hitting the rail bracket where the intercooler cross piping would normally mount. Thought i had the engine in the wrong spot so i moved it as far over to the gearbox side as possible. Still not enough clearance. Out comes Mr. die grinder.
P1330187 P1330188
P1330189
- snug as a bug in a rug! At this point i go around and torque everything up related to mating the engine to the drivetrain as well as joining the exhaust
P1330192
- time to fill up with some Leichtlauf 5w-40
P1330194
- remember when i said things are getting tight? Well putting the front clip back on i was presented with these challenges. First one is self explanatory...
P1330196
- here i needed to remove the bracket that the engine cover sits on so the A/C refill bung could fit. The bung needs to be released from it's holding bracket to be able to move off to the side of the inlet manifold. The two T30 torx MUST be replaced as they hold the variable intake in place (i think).
P1330195
- the A/C pipe to compressor hit the fans. Needed to pull it away somehow... i'm sorry for the cheapie fix but it works.
P1330217 P1330197
- now this was one part that isn't too well documented but will be here in plain black and white. Does the oem 7.1.1. ECU fit (yes!) and does it work (yes.... with some work)
IMG 0087
With the help of LM Tuning in Perth (a timezone away from the east coast of Australia) we decided to just give it a go.
Reactions: S3 Hilife and ToughlilT
Jesus - IanPG ! is this in addition to your stroker? on your other S3? or are you already bored of your other engine? are you turbo charging this engine?
Why dont you try and fit a real hybrid turbo which uses an electric motor to spin up the turbo until the exhaust gases take over? or a twin turbo one small for 1500-3500 or a supercharger and big turbo?
This is in replacement - the move interstate = a change back to something more tame. Funds from old build to go into other things.
This engine will not be turbo'd - however... we will see what happens eh!
Love the purr
Reactions: killfame, S3 Hilife, SamHendry and 2 others
Wow! Your certainly turn this around quickly. Made it look so easy :tonguewink: well done Ian.
Reactions: Stuart B
it's frightening isn't it. I can't even tidy up my bedroom floor quicker than Ian essentially makes a car.
have you mucked around with the map of this? it must lack power compared to your big turbo - and use more fuel? 15MPG?
Reactions: S3AMJ
Sounds mint Ian I’m still tempted to do this to mine
I average 17mpg in my r32 so 15 mpg wouldn’t surprise me
That sound alone is worth 15mpg for sure if the time and funds aloud it... I’d do the same and turbo it!
It’s actually relatively easy considering I’ve not worked on a VR6 engine before. It was just knowing the main parts that needed to be there for the engine to mount in properly then having to figure out a way to make the front end fit because of the tight squeeze. The mk4’s seems to have a little more room down the front.
I’ll make a list of everything I found that needed swapping over / changing / modding to make this happen (I’m looking at you @Tj 0785 )
LOL thanks. It was a quickie and a sneaky one but I needed it done by the time I moved interstate... it still wasn’t done :(
There is a lack of torque busting through the sound barrier feeling but the down low torque, even with 200kg’s of my **** in the boot, in buttery smooth. It’s actually quite nice. It’ll be interesting to see how it is without all that extra weight.
MPG on freeway was actually pretty good. Was at 8-ish on flat ground and up to 15 when overtaking and up bigger hills. Only filled up once. It surprised me!
Reactions: Tj 0785 and S3AMJ
I don't understand the collaration between having a vr6 and interstate? Are turbos banned like cats?
Nah nah. It was jus a deadline to have the engine in and running. To be able to bring the car up along with all my crap.
Is there much room for a turbo with the vr6
Loads... VR tilts forward...
If I didn't need the money for a respray (and could be ar5ed) I'd stick a turbo VR in mine... similar power but more torque and of course the noise!
<tuffty/>
Boost it or gay
Amen. Although Ian is bright enough to fit some alternative mechanism. Eg dual pulley supercharger, compressed air charge reseviour turbos etc. Dual inline turbos, electric spin up turbos
Reactions: IPG
What do you do about the extra lambda sensors do you need the vr ecu aswell or can it be added to the s3 ecu?
this one!
So moving on to he ECU side of things. Not much info online so i was throwing ideas around with Josh from LM Tuning to help me figure things out.
Pulling knowledge from coding in clusters i figured this
- i know what the SKC data looks like
- i know what VIN data looks like
- same with IMMO
- same with key data
Plan A - was to make a hybrid type file with all my 7.5's critical data intertwined with 7.1.1's
Plan B - was to transfer all of the 7.5's data in to replace all of the 7.1.1's data since they start and end in the same spots
Plan C - IMMO defeat
So i went and looked and compared cluster hex with my me7.5 ECU's EEPROM data. Going through the lines, looking for the patterns, finding the matching data.
Sure enough - the ECU also has the all the same data. Although it's in different lines compared to cluster data.
Our theory? Transfer the 4 sets of data across into the BDE ECU. Simple!
right?
emmmm.... no not so simple.
First of all the 7.1.1 didn't want to bootmode on the bench to be able to get a read. Josh had to use another tool to get the ECU's EEPROM data. After that he showed my the 7.1.1 data
Bora ECU EEPROM
Sure enough i can see those 4 sets of values mentioned above in the 7.1.1 file... even better is that they're all at the same addresses!
Major thing that was pointed out is the size of the 5P08C3 ME7.1.1 file is bigger than the 95040 ME7.5 file. You can see all the "...FFFFFFFF..." down at the bottom of the read. The 5P08C3 chip used on me7.1.1 must just have more space on it.
Address lines changed are
30
40
B0
C0
D0
E0
F0
100
Only changing the values required and leaving surrounding coding as is.
Checksummed the file. Again this was a bit of a roundabout way because we had to use a checksummer that's only available for 95040. Had to save the file as a 95040 file size. Checksum it, then change it back to 5P08C3 size.
I made a checksummed file for plan A, B, and C.
Plugged in the BDE computer, battery on, clutch bleed, final electricals check. Key to IGN....
Plan A was the winner. Logic wins!!!
Reactions: superkarl
I don’t know how you get your head round that I didn’t understand one word of it ha. But I have been looking into this you can pick the engine up for £300-450 and have seen a few gt30 kits for this. But they don’t include the engine internals.
Did you go for the bde code on purpose instead of the earlier ones for the vvt?
Ian why didnt you go 3.2 ? (image belongs to Sandip if he's still around here)
1044344_630814493605118_1412283085_n-jpg.20580
I’m sure I’ve seen on here ( could be on r32oc)something about there being more metal between the bores as it’s the same block as the 3.2 means the block as the is stronger which is better for turbocharging plus the 2.8 is 1/3 of the price of a 3.2 engine
Reactions: Dohcwp
HPA suggest that 400-500hp is doable on std internals... you use a spacer gasket to get the CR down... VR engines require less boost to achieve the HP/torque figures that us 20vt peeps have to use so cylinder pressures aren't as great...
Bill had a HPA R32 on the dyno a while back... GT3071 turbo... made 440hp/440ftlbs at 15 ish psi...
<tuffty/>
I’m sure I’ve seen on here ( could be on r32oc)something about there being more metal between the bores as it’s the same block means the block is stronger which is better for turbocharging plus the 2.8 is 1/3 of the price of a 3.2 engine
The angle of the 'V' is greater on the earlier engines iirc...
<tuffty/>
<tuffty/>
Really I episode thought it would be same as a 1.8t although the parts are different I thought it would be same grade metal so would take around the same limits. But that makes this change a whole lot more appealing. I’d probably still be tempted to do rods while engine out
Ian I bet the 204bhp is killing you after the last build
so im guessing the cylinder heads are probably not interchangeable if there's such a big difference in the blocks ?
So here’s an idea, buy a donor Audi TT 3.2. £2000 Take all the engine, loom, Ecu, engine mounts and stick it into the S3? Is it really as easy as that? With some obvious manipulation.
Pretty much...
<tuffty/>
Pretty much could even take the dsg and fit that, but the 3.2 gives less power than my stage 1 s3 although it sounds better would need a turbo for me to do it
Hmmmmmm :smirk: interesting..... well that just adds another option. 3.2 turbo/1.8 hybrid / 1.8 BT. What to do haha
I don’t know how you get your head round that I didn’t understand one word of it ha...
LOL read it again and look at the picture. It’ll make sense :p
BDE is coil over plugs, VVT and double wideband. The loom is also BML ready.
About that... 3.2... well you will see...
The BDE was already pretty much together. Just wanted to do the timing gear and seals.
That’s pretty much it. The comprehensive list (which has all been pictured above) to do a VR6 conversion would be
- engine long block w/all ancillaries (this means you need the accessories bracket + new serpentine belt)
- VR6 engine block mount. This mount can be inserted into the S3 chassis mount.
- engine wiring loom + lambda wiring (both 4mo and R32 looms are interchangeable as long as you get the BDE loom)
- ME7.1.1 ecu + hardware/software to read/write/checksum/match the coding to the S3
- VR6 clutch housing + gear stick cable bracket
- VR6 gearbox to block bolts
- VR6 bevel box + it’s specific bracket + bolts
- VR6 flywheel + bolts
- VR6 coolant lines. Convert to VR6 from reservoir, from bulkhead, from top radiator hose
- VR6 power steering reservoir to pump hose
- VR6 exhaust headers, downpipe and cat (due to the two rear lambda’s). You can connect the s3 back section to catalytic converter. It mates up at the exact same spot. BONUS!
- VR6 n80 hoses/piping
- VR6 brake booster piping (if not just bodge like I did)
- VR6 intake pipe, inlet manifold
- SAI delete plate (you need to code this out to prevent the error showing on scans and CEL). Otherwise add SAI to the list.
Pretty sure that covers it
List copy and pasted I think the biggest drama for me will be the ecu side of it already pricing up gt30/35 turbo kits
- labelling as i go
View attachment 155801 View attachment 155802
View attachment 155803 View attachment 155804
View attachment 155806 View attachment 155805
View attachment 155812 View attachment 155813
View attachment 155811 View attachment 155810
View attachment 155808 View attachment 155809
View attachment 155815 View attachment 155816
View attachment 155817 View attachment 155818 View attachment 155819
View attachment 155823 View attachment 155822
View attachment 155820 View attachment 155821
View attachment 155828 View attachment 155829
TBC
So did you use your gearbox with the vw clutch and bevel box or have I read that wrong ?
824
31
6K
90
15K
