Turbocharger part number
Edinburgh, Scotland
Looking for the 2000 1.8T quattro turbocharger part number. The local motor factors would like this before sending a turbo down.
I have a grainy image from about 10 years when I had the turbo off next to the K04 and I think the blue plaque has 058145703J and the compressor has 53041015095B.
Can anyone confirm that these are correct please?
If its a standard turbo, its a K03-005, or VAG number 058145703H
If your replacing it then it makes no sense to buy a new one the same. at the very least get the K03-029 (058145703J) which is much the same just a bit more efficient, but ideally a K03-073 (06B145703B)
New cost is the same, so you might as well have the larger unit.
Reactions: DieselJake
I was just going to get one from a local motor factor that is refurb. Costs around £480-£80 exchange your old unit.
I don't want to remap or anything for a different turbo but if these would be OK I am happy to get a slight alternative.
Here is a pic of the original unit.
If there are better places to get them then I am happy to go elsewhere.
the -029 and -073 will go right on without a remap and will work fine. Leaves you scope to map it further in future if you desire.
Great thanks.
Anywhere you would recommend getting one from?
Googling places there are a few online that seem to do them for £400 for I assume refurbished turbos.
i've never seen an -073 other than new, they're about 600quid new.
A few places will say they'll refurbish, but obviously they'll only rebuild what you have.
Yeah that is another option. I was thinking a refurb would be the best bet?
I think I would be happy enough with the 029 and that seems to be more readily available.
I saw in this thread turbo specs towards the end #17:
http://www.audizine.com/forum/showt...w-FrankenTurbo-K03-073-quot-The-Mini-K04-quot
"Look at the fin/specs of the turbo. The USDM K03S is a K03-029 which is still a 12 fin design.
K03-005 aka K03 Specs:
Compressor: 36/50
Turbine: 36/45
K03-029 aka K03S Specs:
Compressor:36/50
Turbine: 40/45
K04-015 Specs:
Compressor: 38/51
Turbine: 42/46
K03-073 Specs:
Compressor: 38/51
Turbine: 40/45
the only difference between the K04 and the K03-073 is the turbine size by a little bit.
All the info I just listed can be found on FrankenTurbo's website."
I used to have a K04-015 on the car and it was never mapped and was just run on my K03 remap.
It would boost in a weird way (kind of like a wave of up and down until maybe 4k revs) so I wondering if K03-073 would be similar looking at the specs.
i ran a hybrid that was bigger than the -015 on a stock tune and it just worked.
I did have "wavey boost" at one point, but that was a split DV.
663
939
886
471
9
