Dave70
- Joined
- Nov 20, 2016
- Messages
- 96
- Reaction score
- 147
- Points
- 33
On Tuesday, I had a trip to some shops 7 miles away which included 5 miles on A road. I set off in Dynamic mode, full manual and when I got onto the A road tried to select 8th gear, but it wouldn't have it. It's not like to picked 8th then dropped to 7th, it just wouldn't select it. I changed to Comfort mode and selected D on the gearbox as it usually drops to 8th, but no: 7th. Engage cruise control? Even in S mode, the gearbox goes to 8th with cruise engaged. No dice.
No fault was showing and I thought it could be something to do with the hot weather. External temp was shown as 34C when I set off (cooling to 31C once I got going), engine temp quickly rose to 90, oil temp was mid-50s and rising, air-con was on auto - 'LO', speed around 55-60mph.
I kept trying the paddle to shift it to 8th and it finally allowed it as I neared the end of the A road section and got back into town. The car was fine on the return journey with 8th now on the 'good-boy' list.
Yesterday, weather was much cooler and I did the same trip (I really should write a list!) and it behaved normally, 8th was selected just as normal.
Has anyone else had this issue or is able to suggest a reason for it? This was the first time it has happened.
