I did it on my golf mk7 r for peace of mind last year with decent oil as it's by far the easiest oil change you will ever do no Jack required
What's the wood for? I use an oil extractor so don't have to get dirty at all.
Don't the dealers suck the oil out instead of dropping the sump plug...I'm sure I read a post about this????
Think this is worth investigation...charging for sump plugs...so surely the oil must be being dropped not sucked out!!!I read that too, but they still charge for sump plugs. If they do, I'm using an independent.
You can guarantee you still have at least half a litre left in the sump... wrong way to do it!
I can guarantee you're wrong, because I checked.
Keep me informed please palYep, I will ask mine on Saturday when I go in. If they don't drop it, I am definitely using my independent.
I plan on using an independent for services only did inbetweens in past as was tuned I assume I can take the new s3 anywhere I want as long as they use oem parts ?
