Side Skirt/sill replace
Dom29
Hi all,
My A4 had a bit of a knock on the passenger side and rather than replace the skirt the Previous owner decided to repair it , long story short when the car looks nice and shiny the side skirt looks terrible with dips etc.
Does the skirt just glue on or is it held in place by clips ? what would you suggest , should i take it to be rubbed down and sprayed again ?
Thanks in advance!
They are held on with clips & 3m tape.
I believe they slide off the clips once you use some glue softener on the the tape
Reactions: Dom29
ok nice on thank you , don't suppose you know where i can get the part number from ? or where to find a replacement ?
Thats perfect thank you so much!
Reactions: xpoweruk
Cheapest ive got so far to replace is £75 including the clips , it comes in primer so id then have to get it sprayed thats from TPS dealer wanted £85 , any suggestions of where else to try ? Ive had a quick google but didnt come up with much.
Reactions: xpoweruk
Thanks for the links , half tempted to order 2 for the same price as im paying as 1 and just bang the other on ebay , unless another A4 owner on the forum needs one :) , should i be worried that they arent genuine ? as surely not much can go wrong ?
i wouldn't use fibreglass one personaly .In this instance I would stick with OE
Bought the one from TPS and had it sprayed and put on for £100.
Im happy again :)
Reactions: Macdoon and xpoweruk
One of the most difficult items to picture but it is nice and straight
Reactions: feva
Reactions: xpoweruk and feva
Excuse the landsails
Reactions: xpoweruk
Anyone know if the rocker blades from the b8 or b8.5 will fit on the b9 without problem
