This is on a wet road at +3psi in first gear. Definitely getting better
Sent from my SM-G935F using Tapatalk
Excellent thread for reference @OliS3! Reading through that vwVortex JB4 GolfR/S3 thread can daunting to read at times.
Thanks and glad you like it as much as me, just the standard settings other than what George told me to change in that email I postedInsane pull and nice logs OliS3! What FOL value are you using? My psi peak is on 5500 and 6000, trying to save transmission.. currently running 6.5 psi additive. Love the performance of JB4!
Is there's a big difference over map 2 oli?
Wondering if I should start taking logs now
Wow, stock with just a jb4?https://www.performance-centre.co.uk/blogs/projects/audi-s3-8v-jb4
First S3 to dyno with jb4 ??
Sent from my HTC 10
I was thinking get map 6 right and then I can use the runs for map 2 vs map 6Im going to try and get mine on a dyno , before I mess around with my settings on the jb4 !
Seem like stock with just a jb4Wow, stock with just a jb4?
I need to get to the dyno, my map 6 settings feeling amazing!
You can adjust them on the flyDoes engine need to adjust itself btw maps or can you change them on fly?
So with map 6 and extra torque you can also get on 99ron we could see 380hp with 375 ftlb. That would be impressiveSeem like stock with just a jb4
Sent from my HTC 10
I think it was 367 and had a few mods if it's the same one. Map 6 seems to get about 20ftlb over map 2 and with how much better my car feels I can believe itWould be nice to know what settings were used in jb4. I've seen another dyno sheet of almost stock S3 and it did have 360hp with JB4
I used jb4shop.co.uk and it came a few days later even though the page said it was out of stock when I ordered. You won't be disappointed, it's a massive difference over stockWow im liking them figures, think i need to get JB4 for my S3 wheres the best place to get one from please.
Thanks have a DTUK box at the moment, think will sell it and get a JB4I used jb4shop.co.uk and it came a few days later even though the page said it was out of stock when I ordered. You won't be disappointed, it's a massive difference over stock
The route I took and I've never looked back. Enjoy!Thanks have a DTUK box at the moment, think will sell it and get a JB4
In short nothing lol I've cut the front of the air box and the exhaust flaps are open that's it. Temp was 6cBtw Oli could you write again your mods?
I know that you mentioned somewhere but I have no idea where.
Second question is about ambient temp when you did tests with map 6?
Here where I'm is -5c
Car feels better than ever, mid range is insane compared to even the jb1
Whatever standard is, 60 I thinkOli what fuel open loop you got with above setings?
I'll double check for you tomorrow but I'm sure it was 60 and my air fuel ratios are bang onI'm confused because when I first time opened jb4 I have seen fuel close loop set to 60!
George wrote this:
You JB4 should ship with a fuel open loop value of 40. The maximum you can go is 60. Increasing the value will lower trim levels by increasing rail pressure. Dropping the value will increase trims values.
In short it is worth getting the jb4, the power delivery is loads smoother than the jb1Gents, I need some help please about JB1/4.
I almost bought a JB1 and have now nearly bought a JB4! As a manual owner I am not chasing ultimate power/torque gains just wanting a little more top end umph, if I do not buy any optional JB4 kit (AFR/OBDII) and am not interested in logging etc is it just the same install as a JB1 i.e. does a standard JB4 fit the same as a JB1 with just 3 sensor connections? Does a JB4 just work better than a JB1, is it worth getting the JB4 over a JB1 even if I don't want to adjust stuff?
The is no basic jb4, the jb4 has the obd and air fuel wire. The only way you'll have 3 connectors is with the jb1.OK thanks and still just 3 connectors if I just buy the 'basic' JB4?
