Good morning,
I'm hoping we have a sparkie on the form who can help me. I had some electrical work done last week; a modern RCD fuse board and some extra sockets etc. When it was finished, the guy explained that the earth readings he was getting were too high, and I needed to contact my supply company. Here's word for word what he wrote in an email to help me when I'm talking to the supplier.
"You currently have a TN-S earthing system (earth clamp connected to the lead core of your incoming electrical supply cable), unfortunately the earth reading that this produced was not within regulation, the reading was 2.49ohms.
Explain to the supply company that your electrician has suggested that you would benefit from a new meter being fitted. The current setup is quite old and you still have a 'wheel type' meter. Whilst they are carrying out this work, would they kindly supply you with a TNC-S earthing system. (Where the earth is taken from the neutral bar).
If they will not come and carry out the above work for you, then you will have no option but to hammer earthing rods in to the ground under the floorboards until a sufficient earth reading is obtained."
Before I do that, I was hoping for some pointers on what would be involved, how likely it is that the supply company will do what he's suggesting and also, what are the consequences are if I do nothing but leave it as it is.
Jeff
Jeff
