Need help pls
BIGA3T
Hi all I need some help in identifying the source of my alloy wheel vibrating (making a Hmmming noise)
I have a 11 plate Audi A5 v6 Tdi
I recently bought some 20" alloys which were off a VW t24 - so the same PCD
The car has 30MM spacers on.
After I put the wheels on the front passenger side wheel is vibrating (making a hmmming noise) . I have been to many garages but they can't locate the problem.
I thought about the centre bore etc. But why is it only the front passenger side vibrating and not the others?
The vibrating starts from as soon as I move off, so the wheel isn't buckled.
It vibrates at low speeds and high.
So starts vibrating from 1Mph (as soon as I move off)
What do you guys think it could be.
(All the the tyres are on right etc. Wheel bearing are fine as it did not do it with previous alloys)
Thanks in advance
have you swapped the rear wheel with the front wheel, to see if the problem remains with the front wheel ?
Does it have spacers like this on ?
http://www.ebay.co.uk/itm/Eibach-30...VW-Golf-Mk5-GTI-Edition-30-R32-/142089479977?
Check the length of the bolts that is being used to attach the spacer to the hub. I would take the bolts out and look for any sign that they are possibly too long and rubbing.
Hi I'm using H&R but mine are same as the ones you have posted.
There's two bolts which are shorter than the rest 3. Do you think that's why it may be making that noise ?
seems strange that the front passenger is the one making the noise and that is the one with different length bolts. Which bolts are shorter the wheel bolts or the bolts securing the spacer to the hub.
The wheel bolt length is quite critical when using spacers like these . If the bolt securing the spacer is too long it may contact the upright.
The bolts which secure the spacer are shorter. The wheel bolts are same size. All garages can't figure out what's going on. Very strange.
