I ordered the splitter today from fleabay... £44.00 all inc.
Also ordered 3 packs of http://www.eurocarparts.com/ecp/c/A...1159d25e90784a334df7eabe7fc0788da8208&cc5_932
and a pack of http://www.eurocarparts.com/ecp/c/A...2fdb95564d2fd0e2df12d5c92a9d741cff805&cc5_932
I hope these will suffice?
I must ask what steering wheel is that from? Looks incredibly comfortable! I would like to get one!
I second this, I want a flat bottomed wheel so bad!
Nope, did it on the s3 and most people do it when they fit FMIC of a descent size.Got excited about this today http://www.darksidedevelopments.co....di-a4-b7-2-0-tdi.html#PhotoSwipe1476451291988
Iv prices up the same pipes and hoses from ash hoses and they only came too about 80 quid plus the price of the sensor thing to weld on. And just buy the same size intercooler from somewhere.
Is it a bit crazy to cut the slam panel?
There you go guys...
http://www.ebay.pl/itm/111852522430
The car looks to be in very good company too!6:30 start at work to let one of the service advisors into the building, took advantage of the illuminated, under cover valet bay and gave the A4 a quick wash. Carpro products still holding on well, it's due a clay, coat of black hole and a couple of coats of reload before the winter fully sets in.
Oohhh, how do you do this? Any guides? I have an rns-e, anything else needed?Reprogrammed my car and sat-nav start showing the direction
Well hapy with this 'nnnn
I had this when I bought my car but then it vanished! So do enlighten us please Dimitar
So on Monday morning my coolant light came on at 5am.. I took torch and pooped the bonnet to find BLACK coolant.. level looked okay though.. and I haven't checked the coolant in about 12 months so thought maybe its time for a flush and a fresh.
That evening checked it again and OMG the coolant was OIL!
The oil had separated on top of the coolant so I managed to drain it all out and top the coolant up to see if the problem carried on.. 1 day later just a small amount about the size of a 2p in the top.. 1 day later another litre of oil in the coolant! ****!
I'very dine some research and it appears to be one of three things..
1. Cracked block
2. Cracked head
3. Head gasket
4. Failed oil cooler
I have had no usual signs of any of the above and the car still pulls like a train.
I have been and fitted a brand new oil cooler and flushed the coolant system many many times.
Tomorrow I'm going to flush it again and then take her on a long drive.. fingers crossed it solves it.. otherwise I'll be looking for a replacement car and breaking this one.
Wish me luck!
Anyone going to cars and coffee tomorrow?
I'm not Vag-com guy but i use to have a few problems over the weekend with my sav nav and i try to re-code in chanel 37 and then adaptations + number for sat nav ... this is what i done but same time I changed the mechanics on my Mk2 so that may be the key !
Never before had these
Tough day today
Got some parts but as always not all that glitters is gold.
Got a set of xenon that had been Joey'd and a RS4 genuine grill
All went well until testing.
It would seem previous owner ran resistors in the NS light, which has made a mess inside of wiring (melted)
Lots of circuit testing and coding and luckily it will only cost about £10 to sort out but another couple of hours messing about
Early shots as I need to get my gaps perefect but here you go
A4 Genuine BI Xenons
Genuine A4 B7 Grill
Fog lamp intakes Meshed with genuine RS4 mesh
Will get some better day pics
