New A3 Sportback owner 2 weeks in lots of changes **PIC HEAVY**
dpbayly
Royston, Herts
Hi all,
Been looking around the forum for a few weeks since accidentally becoming an owner of a 2006 A3 S line sportback 2.0 TDi 140 and I'm not one for standard cars and I have no patience at all so when I start I like to get it finished asap and the A3 has been no different, I'm a Mechanic of 17 years and reasonable paint sprayer.
I'm not new to Audi-Sport
My previous cars have been my TT about 6 years ago.
I bough it like this:
and 10 weeks later it looked like this:
My nex Audi was an A4 3.0 V6
Bought like this:
and 12 weeks later looked like this:
So they were a few of my previous Audi's and now for the new little A3 and a few pic's and details of of the work I've carried out
Here's is the A3 as it looked when I picked it up it was standard really all apart from the mk7 Golf GTD alloys:
My first modification was to fit a set of LED bulbs in place of the fog lights and then rewire them to run as DRL's :
Next was to try a set of new HID bulbs and because I have halogen housings I thought I'd try the shielded HID 8000K bulbs and they work great and on the beam tester in my MOT bay the pattern is sharp so I'm very happy with them:
Next was to address the rear lights by fitting the facelift bar ones and to code the the car to operate them correctly:
before:
new light units:
Fitted along with my new LED number plate light units:
Next was to fit the very versatile Seat Lean Cupra R splitter:
Next and very annoyingly I had to fix a small dent in the drivers side rear door bottom after crashing my ride on lawn mower into it .......... DONT ASK.....
all fixed
Next was to try these fitted sun shades I normally have the windows tinted but this time I though I'd give them a try and I'm very happy with them:
Next a little bit of head light tint film, this is the lightest and has no noticeable effect on night vision and I've used it many times:
left done right not done:
Both done
Next was to fit a new honeycomb front grill the one I bought like many have has the top 2 sections of the honeycomb filled in which I soon had removed:
half done:
the fitting process:
Fitted but without the rings I also before fitting masked up the grill and sprayed the rim high gloss black:
My first splash of bold colour:
next was to remove the fog light grills and mask them up and pick the bar and fog light out in gloss black and the raised rim around the light in the same ring red:
Next was to change the wheels as I'm not a fan of the mk7 golf GTD wheels so was very happy to pick up a set of 19" Genuine Audi Speedline splits 19" x 8.5 " ET43:
The following morning I split them and started the refurb process which took a couple of days:
First step was to key the surface with scotchbrite:
I also decided to spray the rims instead of getting them re diamond cut because my wife WILL curb them and if painted there easier to touch up:
Primed:
Next was to set about painting the centres:
The finished centres painted and lacquered :
Now for the rims I first went over them with alloy wheel silver:
I then dusted them with a coarse silver flake:
I then gave the lips a light coat of red metal flake:
I applied this with my air brush:
It's very hard to capture the effect of metal flake on camera :
Here's the wheels bolted back together:
I wasn't going to fit them till I was lowered so when the Eibach sportline springs turned up yesterday I last night slapped them on:
And here it is I WAS VERY DISAPPOINTED in the drop it was nowhere near what I expected:
So last night after I took the pics I was amazingly offered a set of AP coilovers which I collect at 10pm and this morning at 5.30am I got to work and picked it back up on the ramp and removed the brand new 6 miles old Eibach springs and my S line shocks and popped the coilovers on instead:
Im now chuffed to bits of how it sits.
This was how it looked before I set it up to my preference:
Finally my finished pictures:
A couple of before and after:
Sorry for the long post but I had a lot to show.
That's some pretty impressive upgrades to do in the first two weeks . What else do you have planned for the future ?
I have 18" speedlines and have always wanted to upgrade to 19's . Did you have any rubbing issues ?
Reactions: dpbayly
Thanks,
I'm removing and painting the rear badges tonight the same red and I'm undecided if I'm going to refit them all back or just the rings and leave the A3 and 2.0 tdi off yet and then that's it for the foreseeable but you never can tell I might spot a mod on here and think"I'd liked to do that".
As for the 19" speedlines I was at first a little concerned as the offset and width put these 19mm further out than the GTD alloys but they do fit even as low as I am with minimal work, I trimmed the rear liner and remove the front liner top middle screw and they clear with no rubbing so far and that's with 225/35's as a pose to the recommended with this offset and width of 215/35's
That is a lot of work in a short space of time. I wasn't sure if the wheel colour, but I really like it, the contrast is quite sticking. Very well done. I hope you have the time to enjoy the car now :)
Reactions: dpbayly
Thanks.
I have no intention of moving on from the A3 for a while, with our first baby due in 7 weeks it was a case of get it all done asap while I still have the time to do it.....
Thanks.
It's a great car for all the baby necessities. :)
Exactly my thoughts.
4 doors
Decent size boot
Great economy
Great reliability
And great looks
And the baby will require all available space. Wouldn't have it any other way though. 7 weeks will fly past. :) x
Reactions: dpbayly
Very nice mate the wheels look good
Reactions: dpbayly
I have to say I'm very impressed with the AP coilovers they ride so well and as my first ever set as I always just use springs simply because I thought all coilovers were bone shakingly hard but these ride the same if not a bit smoother than the stock S line springs I removed
Impressive for 2 weeks work! Can I ask where did you get the film to do the lights?
Thanks.
No problem, I've used this same film for 5 cars including this one it can be also used on the rears as well you'll need to use a hairdryer to stretch it over then go over it after with the heat and a pin to eliminate any small bubbles that get trapped to leave a great finish.
Here's the link:
http://www.ebay.co.uk/itm/30cm-x-100cm-Light-Smoke-Black-Tint-Film-Headlights-Tail-lights-Car-Vinyl-Wrap/191288517507?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=35391&meid=830a74f0f19346cda785cadf5fa86e22&pid=100005&rk=1&rkt=6&sd=272247200051
100cm is just about enough to do the pair of front lights on the A3 but as it's so cheap it's worth buying 2 rolls just in case a mistake is made.
Thanks.
Here's the link:
Ahh ok thank you for that will be keeping an eye on this thread
Rear end has now been finished with the removal of the "A3" and "2.0TDI" and the colour coding of the rear badge to match the front badge and wheels:
I
19
imported_wolfpacker
I
