Hey I was wondering if anyone knew what the physical if any differences between the 2 engines crbc 150 ps and cuna 184 ps or whether it is simply diffences within software
AFAIK they are basically the same engines. If you have a look here and compare the different parts of the engine you can see there are different part numbers for some parts. http://www.partsbase.org/audi/audi-a3-s3-sportback-qu-a3-eu-2013-8v-d-000-001-engine/
The engine code for the 184BHP is CUPA .
The turbo part numbers are different as are the clutch and flywheel. Things such as the crank / pistons and rods are the same. There are other differences between them some more important than others. The block is a different part number. As are the injectors.
I was going to say that but it just seemed so obvious, surprised nobody else had already said it.
CUNA and CUPA are I believe very very similar. Same power output, possibly slightly different emissions spec. http://www.seatcupra.net/forums/showthread.php?t=373549
