injector issue (i think) 3.0 tdi 55 palte - 152k
jabba
right so i have been noticing more and more white / blue is smoke on idle i have been googling away and there are many bits of information available and some have been fantastic bits of information and some are just confusing.
i am basically after confirmation of my thoughts before i start spending £200 on injectors ( i think i need 4 Min)
i am happy to the install just want second point of view.
measuring block 75,76,77
DSC 0035
measuring block 72, 73,74
DSC 0034
i have found a very useful page on here or other forums regarding A8 techs description
ie first value over 45 (example 60 ) second value over 15 (example 20) are leading to defective injectors
and install information
http://www.audi-sport.net/xf/thread...tor-removal-installation.194985/#post-1930400
so this leads me to think i have 4 duff injectors (two very duff - 1 & 5 as i have replaced the glow plugs last week)
i have a video of the exhaust ill upload too.
if any one can spread some light on this i would be much appreciated
thank you in advance.
oli
From what I have read of this issue and the symptoms you describe along with the age of the car it pretty much sounds like the injectors.
I would be tempted to change all 6 if you are going to keep the car. The other 2 are probably not far away from failing.
If you are able to do the work yourself then possibly change the 4 that are the worst and monitor the other 2.
Reactions: jabba
Also found the link with the info on regarding values for future ref if any one is intersted,
http://www.vwaudiforum.co.uk/forum/archive/index.php/t-142646.html
thanks desertstorm, my worry was it was an some thing else, unfortunately there is no error code for this, i have made the job and trying to see if this is a injector issue by buy injectors of a low mileage car (60k ish) and swap them out the worse two to see if that cures it etc.
so has any installed second hand injectors?
Yes I installed 1 on it's own a couple of years ago, with no problems
