As I started this thread about 2 years ago I'll give my update...
2000 S3 APY
212,500 miles
Just to add - nothing lasts forever, the amount I've replaced/modified on this car basically means I'm driving the equivalent of 'Triggers Broom'
Still have no intention of changing so bring on 1/4 of a million miles
N249 by pass
SAI removed with Forge blanking plate
V1 B5 TIP with Jetex filter and heat shield
TFSI coilpacks with oem plastic adapters
PCV venting to air
New fuel lines last year
AGU head with single piece exhaust valves and cat cam exhaust springs
BBT FMIC
Several silicone hoses and Porsche oil/coolant caps
That's about it for the time being directly done to the engine but definitely will be looking for some more power soon
Interesting mate Hopefully mine lasts as long. What was the story behind the new head? APY head loosing compression? Also is your bottom end still original?
