I'm new to the forum and have the opportunity to buy a manual, 2004 A3 quattro off a friend. After Borrowing the car for a few days (and loving it!), i noticed it was hesitant around 2k rpm........ Ive trawled around the forums and found all the various suggestions on getting this fixed. Ive also had the car plugged in on vagcom at a local garage and they confirmed that there is a significant misfire around 2k (revs wont hold steady in neutral) i should have the data all printed off tomorrow and be able to explain better! i believe the readings were also around -3 / -4 and from what i understand a reading of -8 suggests cam chain stretching!!
I would hope that the solution would just be to get the ecu updated at a local Audi dealer, although i'm not sure its a risk worth taking as i have seen the amounts people have spent trying to rectify the issue.
The car itself is a red, manual, S-line, with 9 months mot, 4 new tyres and 96000 miles. As it stands at the moment he wants £3750. Do you think with a bit of research I could narrow down the causes of the misfire or would i be better off searching elsewhere? The last thing i want to do is open up a very expensive can of worms!!
Thanks, Joel
Thanks, Joel
