S3 Exhaust Valve
MEddy78
Surrey / West London
Hi all,
I had much car serviced today and the technician (a good mate of mine and an Audi trained tech) - noticed the vacuum pipe for the exhaust valve had been disconnected and 'bunged' with a screw, this left the valve in the close position. As the valve can be opened / closed he removed the screw and fitted a new piece of vacuum hose.
From what he said and from other posts I've read, the valve allows to car to be quieter a low rpm then open up as you put your foot down thus making a bit more noise ....... so with it reconnected I took the S3 for a blast but didn't really notice much difference?!?
With the car stationary I put my iPhone in video mode under the rear box and filmed the valve as I rev'd the engine - nothing happened!
Is this because revving the engine does not 'create' the same driving effect that would normally operate the valve or is something knackered? How could I test it / prove it's now working?
Thanks :aggressive:
They don't move when stationary but you should notice it slightly noisier above 3500 rpm.
To test the actuator just put a piece of pipe on and suck which should work the flap.
Reactions: MEddy78
Not sure how you'd test the control part.
When you look inside my exhaust the flap is open when the engines off and you can see the flap has a clean edge from moving.
Is your flap in the closed position?
No, like yours it is open with the engine off, its a bit late to start the engine but with the engine running at idle presumably the valve would close?
Might just revert it to how I found it as in the month of S3 ownership it's all I've known and it hasn't been a problem!
Thanks for your replies :)
On idle and revving while stationary my flap stays open.
It must close once you move off.
I know mine works as I'm running a 3" downpipe and I can hear the difference when it opens.
Reactions: MEddy78
