AUDI A3 8VA SportBack 16 Ambiente Business: steering wheel and vocal controls.How ?
lukappaseidue
Hello everyone, I'm a happy owner of a fantastic 8VA Audi A3 sportback 1.6 TDi Ambiente with business package.
My car does NOT have the steering wheel controls, and consequently even the voice commands (I'm still thanking the seller that the advice (not) gave me
Now I feel the need to recover them.
Does anyone know if there is any chance to recover both the steering wheel controls voice for those who operate the system MMI Base Business packet 5.8 inc?
It is possible to activate TPMS by VCDS?
thank you very much
can't say about the steering wheel but as far as the TPMS goes its not just a case of using VCDS to enable it .there is extra wiring and controller needed and when this becomes available it could be £300 ish for the parts alone.
Reactions: MKC
Sounds like you don't have a UK spec car as we don't have an 'MMI business package' and the voice commands are standard here.
There is a thread in the VCDS forum where someone has made some good progress enabling TPMS with VCDS, but I don't know how much it would be to retrofit the steering wheel with voice command button. User 'NHN' on here may know as he retrofits a lot of things.
I've installed, aftermarket by AUDI original spare part (retrofit) steering wheel command; but at authorized AUDI workshop was not able to activate voice command.
This is the question:
I'd Like to know if Can I activate VOICE command onto my AUDI A3 8V (sportback edition) SportBack 1.6 that come with MMI basic 5.8" sat-nav, Bluetooth handfree e steering wheel command, but not voice command and "*" key is not coded.
Tuesday,08,July,2014,22:34:26:14849
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.7.0.0
Data version: 20140601
VIN: WAUZZZ8V8DAXXXX License Plate: XXXXXX
Mileage: 20515km-12747mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V8DAXXXXXXX Mileage: 20515km-12747miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5516
Revision: 84H22---
Coding: 02190012032401092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
ROD: EV_ECM16TDI01104L906021AL.rod
VCID: 6FEBA25FB6A70D4286-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 12F162A220270A740180060401C82548460450806080A4F20259000405
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7DF78817ECCB6FD204-8028
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H09 0031
Revision: 20017000 Serial number: 00000000015064
Coding: 03000104002000001000000000000100
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 35675037947B77928C-8060
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011311200381
Coding: 04000A42C2C1227D03844000001C07A8000C000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 468527FBF99DEC0A15-8013
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 130412 041 0580
Serial number: 130415184616
Coding: 0A47F7
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A
Component: G397_RLS H06 0002
Serial number: 20112867
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 05 03 2013 00000197
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831310802177
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002015
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 377B5A3F8E7785829E-8062
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R017KNJ
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 4B9316CFE2FF1162CA-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 604 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000A39309C0V
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 604 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000000279D0D0U
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 304 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502C50FEA2160304
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 304 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502C70FEA211930B
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 503 13
Component: FrontSensor_D 001 6149
Serial number: 35565029B0FAE894331R
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A70FAE8A2F0B+
Coding: 2D2D2D
Pedestrian protection crash sensor; passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_P 001 6149
Serial number: 22965029D0FAE8A5530W
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 401 604 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C90FBDE34C0B-
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 C HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 20041308490755
Coding: AE08
Shop #: WSC 30488 000 1048576
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 3A7D430BBD6598EA61-806F
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 B HW: 8V0 920 870 B
Component: KOMBI H24 0570
Coding: 07A40A002A80000804006800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_AU37.rod
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 125 1126
Revision: -------- Serial number: 0000529803
Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_AU37.rod
VCID: 3879590383698AFA97-806D
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 06 01 2014 B1288208
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051251001
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 12041303110049
Coding: 001C0E205C00040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 3F8B321FA647BDC256-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D774817AC4BAFD244-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 06041306071109
Coding: 001C06205E00040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 3E754F1BA14DB4CA5D-806B
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 018A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E79037D4FB37924C-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 864 B HW: 8V0 035 864 B
Component: MU-S-N-ER 040 0420
Serial number: A3F00703143183
Coding: 01730301FF00000021110001000A00002F0004440100010006
Shop #: WSC 62665 001 1048576
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 A HW: -----------
Component: ECE 2013 --- 0021
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H48 0013
Serial number: AUZ8Z9DY3004UU
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000006031300010138
End-------------------------(Elapsed Time: 03:38)--------------------------
some questions:
in 5F module I've changed the last number from 4 (orginal one) to the actual 6. with this I can see the VOICE menu (SDS) in the MMI and the function is ok, but only for minutes. Pushing the SDS key (with icon face), beep, a windows is displayed, I talk and my car listen to me. But when I switch off the car, and than switch on, the function is lost. When I push the key of SDS, non beep, and no ear, I only can see a windows with the icon face, but nothing more. The MMI Voice menu is still there.
Another strange thing is that the " * " was not coded. Nothing appen when pushing it.
So I've found this coding:
5F: Adaptation
(77)-Vehicle function list BAP-MFL_Jocker_0x34 - Activated
(1)-Vehicle function list CAN-MFL - Available
(146) Vehicle menu operation MFL_Jocker - Activated
With this setting I'm able to set " * " but the VOICE MENU SETTING is SETUP -> CAR -is not more shown even the code for this is unchanged.
This are my debug log:
Code:
Address 5F:8V0 035 864 B recoded (ADP-(77)-Vehicle function list BAP-MFL_Jocker_0x34) from not activated to activated Tuesday,08,July,2014,23:11:31:14849
Address 5F:8V0 035 864 B recoded (ADP-(1)-Vehicle function list CAN-MFL) from Not available to Available Tuesday,08,July,2014,23:12:35:14849
Address 5F:8V0 035 864 B recoded (ADP-(146)-Vehicle menu operation-menu_display_MFL_jocker) from not activated to activated Tuesday,08,July,2014,23:16:58:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010006 to 01730301FF00000021110001000A00002F0004440100010004 (62665/001/1048576) Tuesday,08,July,2014,23:27:58:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010004 to 01730301FF00000021110001000A00002F0004440100010006 (62665/001/104857) Tuesday,08,July,2014,23:30:38:14849
Address 5F:8V0 035 864 B recoded (Long Coding) from 01730301FF00000021110001000A00002F0004440100010006 to 01730301FF00000021110001000A00002F0004440100010004 (62665/001/104857) Tuesday,08,July,2014,23:34:47:14849
Please, help me activating SDS
Revision: 84H22---
Coding: 0A47F7
Coding: 00006C
Coding: 0000040001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: AE08
Alternator:
Coding: 81
Sound System:
some questions:
5F: Adaptation
Code:
EDIT: yesterday I left my car with SDS coded, but no MMI menu. This morning, when switching on the car, the MMI SDS menu was there !!! and it was ok (i speak and car listen my commadn) until stopped car for mor than 10 minutes!!!
PLease, help
