mountain_man
Just replaced my burnt out rear wiper motor. On my A3 8P 2006 Sportsback with one from a MK 4 Golf... This is the serial code for the golf wiper.
I brought the car from south coast and think it was a hard water area as the tubes had got blocked up and caused the motor to burn out and washer fluid to flood the motor and in into the boot cavity, rather than out the nozzle.
As you can see it..looks like they were filling the wash jets up with mud...
Was a pain in the **** to get off but i found the best way was with lots of WD40 and a chisel to pry the wiper arm off the spindle...It is held on by friction and rust. I used the chisel to lever the wiper arm up away from the spindle.
I hope this helps as a cheap and fast way to get the wiper arm off. I had read about getting special pulling tools etc..
Wiper problem fix all for less than a £10 cant be bad
