Hi,
I have a 2001 A3 1.8T which has it's ESP light stuck on. I've plugged it in at various points over the past few months trying to diagnose the issue (clearing faults to see if they return) and have also had an auto electrician check over fuses, earths and power to the ABS Control unit (these all seem fine).
One fault persists:
00538 - Reference voltage
Whilst the following have shown, but since cleared:
P1649/18057 - Powertrain Data Bus: Missing Message from ABS Controller
01435 - Brake Pressure Sensor 1
00532 - Supply Voltage B+: Signal too Low
With everything checked over, minus the enclosed unit itself I'm fairly sure its either the ABS Control Unit and/or Hydraulic pump.
I know these things are somewhat famous for going wrong, but ahead of forking out for a new unit I thought I'd check if anyone had experienced the above faults and whether a new control unit / hydraulics had fixed the issue?
Thanks in advance.
Allan
One fault persists:
Thanks in advance.
Allan
