Hi Gents,
I purchased my DTM about 6 months back, needed a few minor things addressing but have been modding and getting what I can over the last few months,
spec so far... :-
green panel air filter
HPFP autotech
Forge actuator (modified to fit ko3 for a4)
forge dump valve
RS4 fuel pressure reg valve (put on but taken off until I get big turbo as fuel pressure was too high on fuel rail)
RS4 thrust sensor
FMIC full kit (ebay order from America)
decat pipe (from America)
full stainless exhaust (custom made to match milltek specs)
H&R 45mm lowering springs.
H&R anti roll bars front and rear.
Forge full big brake kit.
southbend stage 2 clutch and single mass flywheel
19'' CADES BERN wheels with toyo proxes T1R tyres
15mm rear and 12mm front wheel spacers
JBS fitted the clutch and sent the actuator away for modding to forge and remapped it for me.
Excellent service from them and very experienced with VAGS..
Just ordered this week and need fitting, front snub mount, full set of poly suspension bushes, rear braided lines, front ultra racing strut brace and decided to go over to the dark side and ordered the AP coilovers...
Mods to come are larger turbo ( Olethalb ) am thinking of pinching yours, S3 injectors, bigger in tank fuel pump, plugs etc.
Will run and see what I can get on standard internals then maybe think about pistons, conrods, head work etc..
