S3 GHO
OK, long story but i'll keep as short as i can.
Bought my S3 in June at a very reasonable price and knew of a few issues that i'd need to sort (brake caliper, oil leak, exhaust leak somewhere at the manifold) but, overall its a very clean car.
So...... Took the car to A for Audi in Glasgow to check the car over, cleared a few faults (Lambda & Overboost) and they said a few hoses needed replacing which is fair enough at 102k miles. BUT, when i went to drive the car away, I got some quite thick blue smoke out the exhaust so spoke to them and they said possibly due to the hoses being moved / squeezed and possibly getting some oil into the cylinders .....? Not sure. The smoke cleared after about a mile or two and car ran normally.
Took the car to Bedrock Veedubs in Motherwell as its closer to me and think theyve got quite a good rep and got them to do a health check and replace the vacuum hoses and any others needing done - 7 in total inc the TIP where they replaced the standard wit another standard one which im annoyed about as i'd like to have put on a Samco or similar............ but anyway. 7 replaced in total which has (or seems to have) solved my oil leak as oil was spraying out of one or more of the pipes. I havent fixed the exhaust leak as yet.
Problem is now, that i noticed some very small pufs of smoke out the exhaust (blue smoke) driving off boost intermittenlty. very infrequent if im honest but i've noticed some light black dust on the rear bumper, very light but question is should i be concerned?
The car is driven very lightly with only the odd blast here and there, warmed up and cooled down properly and otherwise is great. I just wondered what you guys think?
What i'm thinking is:
Valve Stem Seals
Turbo Seals - Although its not smoking on boost as far as i can see.
Apologies for the length but just wanted to paint the full picture.
Also car is standard i was told when i bought it - but doesnt feel standard. Personally i think its been mapped at some point.
Thanks troops
Valve Stem Seals
Thanks troops
