Audi S3 Steering rack replacement
You would need to check part numbers tbh to make sure it shows up under your car as there are a few about, also its probably a gen 3 version & you may have a gen 1 or 2, most likely 2, so may need an adaption loom & coding, so beware & do you research 1st.
I know mine is a gen 2 and I think the new one is a gen 3. Do you know the part number for the adaption loom? The rack I'm looking at comes with the cable to the battery box area and another 2 multi plugs I guess the adaption loom will be the bit between the 2 multi plugs and my existing cabling. Sorry if i'm sounding stupid but I'm just a bit wary because there are so many different part numbers...
Audi will have notes on there parts system etka as to what loom will be required, so go in with rack part number & see what loom it advises, but again you need to verify the rack will support your car 1st, dont buy any old rack.
P
9
588
H
533
903
enc
