doh doh and doh again errrrrr, just got a call from garage saying timing is all good on chain and belt and he said car needs an autolec to now check loom etc but hes done a compresion test and cylnder 1,2,3 are 9.8bar but 4 is low at 7.2bar checked head gasket with die test and all is fine ther so possibly valves or pissten rings ,
so collected the car and decided to take off the rocker cover and set timing tdc and to my amazment the two cam chain marks dont seem to be alignd is thi right or has it slipped a tooth if so whats involved in fixing it? also if it is wrong is this the reason why one cylinder is down on compression mayb a valves not fully closed? if thers anyone that can help thatd be awsum,
