My wife A3 1.8 quattro sport won't start.
she drove home yesterday all was fine and when we went to go out today it just turns over but doesn't start.
has anyone else had this?
I've now managed to run a scan and it came up with "engine control module incorrecly coded"
I cleared it and now the car starts with no code coming back BUT why did this happen and it's worrying that it could happen again at any time.
the car turned over fine for a while and the battery didn't seem to dip in power.
It could be a the wires but odd that it would just do that.
The car isn't modded and has been fine.
ok it happened again this morning. car started and got to the shops then wouldn't re starts.so she cleared the fault code and it still won't start but turns over fine and it was the same code. could it be the battery? it does turn over strongly so maybe not. I am baffled by this and we need to get it sorted ASAP.
Well if he's turning strong I doubt the problem is the battery. Is it possible that it could be a dodgy earth or connection, seems unlikely/daft that the ecu and dash could have forgotten its coding. At this point I'd be taking it to an auto electrician
