Hi all, when I brought my car I ran VAG com and it showed that the signal for the engine temp sensor was impulsive, it was then that I noticed that the temp gauge didn't actually work. I located the sensor, pulled it out and gave it a clean and refitted and it worked. Next time I started the engine it had stopped working again. Fiddled with it again and it worked then a repeat next time I started the engine. Would this be a fault with the sensor or the connector? Cheers lee
