Revo stage 1 - what are your Performance Mode settings?
elton121272
Glasgow
As the title says ther are 3 settings for:
Boost/Throttle Response
Timing
Air Fuel Ratio
Just wondering if the settings were standard to all stage 1 re-maps from revo or what the general consensus was if varied?
I have a '10 plate S3 SB BE which is totally standard.
Thanks in advance.
A lot of the guys here have different settings although I'm not sure how it's changed.
Can anyone confirm?
Im running these on REVO Stage 1, very happy with peformance and delivery characteristics although I have never done any logging so not sure about correctional factors.
Boost - 7
Timing - 6
Fuel - 9
Car is ALWAYS filled with V Power (99 ron).
Good luck
Paul
Hi Paul, from experience of doing lots of logging myself I would suggest you perhaps take the timing back to 5 in the hotter weather as I would imagine you are pulling a fair amount of CFs unless you have an uprated intercooler installed?
KRL how do you actually change the settings?
REVO supply a device called an SPS Plus. It allows you to adjust fuel, timing and boost. You can also use it to put your car into stock mode, valet mode or anti theft mode.
Great bit of kit :)
Do you mean the select switch thing?
Yes. There are two of them though. The Select switch only allows you to switch between pre configured settings but does not allow you to tweak boost, timing and fuel. The Select Plus does allow you to tweak boost, timing and fuel.
Thanks KRL - Think I'll go dig out the old box to see which one I have. Might be lucky as the switch was a hand me down. Fingers Crossed lol.
Here is what I think mine are set for - how do these compare?
Boost: 6 (Performance boost)
Throttle Response: 5 (increased response)
Timing Adjustment: 5 (predominantly for 98 Octane fuel with occasional 95 octane use)
Fuel Adjustment: 9 (Performance Air Fuel Ratio)
I only have 3 settings on mine: boost, timing and fuel.
Thanks mate, need to get me a Select+.
Paul
Just bought a Select Plus for a 2.0TFSI which is REVO1'ed. It is in for a service Weds so going to ask them what setting are on it at the moment.
Does anyone else have a plus w 2.0TFSI? Just wondering what settings people are running??
I find the current performance patchy - sometimes it feels v quick, other times not so.
