Your boost readings in what gear ??
Bradderz_1988 Jul 10, 2011
  1. Bradderz_1988
    3,899
    230
    What peak boost are you seeing in your gears 1st -5th as I want to now if mine is correct.
    TQS owners prefrably.
  2. Bradderz_1988
    3,899
    230
    Mines as follows
    1st - 5-6psi
    2nd - 6-8psi
    3rd - 8-10psi
    4th and 5th - same as 3rd
  3. B5QUAT
    B5QUAT Member
    317
    13
    Not sure about first, as I tend to be quite mechanically symapthetic, but in the other gears mine his 12 psi dead which tails off to about 8-10 as the revs rise.
    In 5th it sometimes hits 14 but more often than not, it's bang on 12, angain tailing off as the revs go up.
  4. Bradderz_1988
    3,899
    230
    So looking at my readings there's something out of the ordinary then would you say ?
  5. aragorn
    17,886
    688
    Whats your airflow figures like on vagcom?
    AJL (and AEB) doesnt have a boost sensor. It works out the boost pressure using a load calculation based on the airflow, so if the MAF is a bit dodgy and reading incorrectly you can end up with squiffy boost. Your fuel trim values might also show something odd if its a MAF fault, and you did say you had a fault code about mixture, which again might point at the MAF.
    I dont have a gauge, but i've pulled a log thru second and the airflow figures show a nice flat torque curve ~170lb/ft which is the book figure, so would suggest that the car is making full boost in second gear.
