You May or May Not Know ........ Tips & tricks
NOZ Mar 14, 2013
  1. NOZ
    NOZ Member
    208
    21
    Been surfing the web and came across a few tips and tricks some of which were new to me and some that might be common knowledge but i thought i would share please add to the list and comment if they work these are all without using VAGCOM
    Enjoy
    Key Fob
    Pressing and holding the boot unlock for 2/3 seconds will unlock the boot ( unlike a single quick press to unlock the doors)
    pressing and holding the unlock button for 2/3 sec will open all the windows and and the same to the lock button will close them all
    Window pinch
    press and hold the window up for 5 sec, press down instantly to open the window all the way and hold for 5 sec while its down and instantly close again and hold all the way to the top the pinch control is now stored
    Throttle Body Alignment
    insert ignition key and turn to before the starter motor is engaged (do not start the car ) push accelerator to the floor wait 3 sec turn the key all the way back but do not remove. release the accelerator and wait 2 Min's remove the key put it back in and start the car you should notice a better response when pressing the accelerator (do this action every few weeks)
    reversing. passenger wing mirror auto tilt ( so you don't scuff those precious rims)
    move the wing mirror switch on the drivers door to the passenger adjustment position put the car in reverse mirror tilts down and shows you the kerb .( may not work on some cars )
    Climate control
    hold the auto button on the drivers side for 4 sec and release now you can control both temps with the driver side + & - buttons
    to reset and revert back to independent control just use the passenger + & - button
    turn on and off the instrument display
    by pressing the reset button twice
    De-Bose
    on the radio press and hold the menu button till you get to the Nav/ Radio or something menu and turn it all the way to zero position and press the button again the system has been de bosed and the Bass is louder
    Sumner and .Jas. like this.
  2. Danny-boy
    Danny-boy Member
    488
    19
    Interesting stuff, a couple there I'm defo going to try.
  3. B_FUR
    B_FUR Active Member Audi A4 Audi Avant Owner Group
    488
    90
    Cheers for that mate. Will try a few out wish I'd tried the auto tilt mirror the other week when I scuffed a bloody alloy!!!
  4. Danny-boy
    Danny-boy Member
    488
    19
    You scuffed an alloy?
    Naughty step!!!!
    Wonder if it works on mine, it's fairly poverty spec so I doubt it.
  5. NOZ
    NOZ Member
    208
    21
    please post your results guy's and if you have any tips & tricks you want to add whack em on :thumbsup: and share !
    the window key fob , boot unlock , and throttle calibration, & air con dual control all worked for me gonna try the rest later
  6. mehtaman
    mehtaman Member Team Daytona s tronic saloon
    91
    I've used this to reset my window regulator / anti-pintch sensor:
    Start with the window all the way up.
    Hold the switch down until the window is all the way down
    Hold the switch up all the way until the window is fully up
    Continue to hold it up for 10 seconds.
    This should reset the pinch sensor.
    The issue I had was that if I opened the window, when I tried to close it again the pinch function would kick in and it would drop the window again... bit annoying when your driving and rain starts to fall.
    It also helps to clean the green slim build up on the window seals :)
  7. B_FUR
    488
    90
    was not happy i can tell you!!
    mirrors don't work, boot release does, always though button was broken!!
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado quattro Audi S4 Black Edition s tronic
    8,036
    2,484
    Er...the boot opening button press is in the owner's manual.
  9. gruf
    gruf Member
    288
    14
    did you know that you can fit 2 mcdonalds dips into the little rectangle by the cigarette lighter by the handbrake, nuggets and dips without no spilling
  10. Wrath
    Wrath Well-Known Member
    1,196
    41
    Fantastic observation :)
    gruf likes this.
  11. B_FUR
    488
    90
    and if I had an owners manual I'd know that ....
  12. Danny-boy
    Danny-boy Member
    488
    19
    To be fair, I only knew this via my owners manual.
    I read it cover to cover when I first got the car.
  13. jdp1962
    8,036
    2,484
  14. jdp1962
    8,036
    2,484
    A man after my own heart.
  15. B_FUR
    488
    90
  16. shahedz
    shahedz Member
    Is the mirror tilt only available on those cars with with memory seats? This used to be the case with my BMWs if I am not mistaken.
  17. NOZ
    NOZ Member
    208
    21
    i thought my boot release was up the spout to I'd been pressing the door unlock 3 times to open the boot once i stumbled on this there was no going back lol
  18. NOZ
    NOZ Member
    208
    21
    undoubtedly the best tip so far lol Good work fella
    gruf likes this.
  19. jdp1962
    8,036
    2,484
    Failing that, bite the bullet and buy one. Sounds obvious, but there's so much in there we need to know.
  20. ESD1711
    ESD1711 Active Member
    691
    219
    43
    Hahaha - i actually made this very same observation for the first time last Saturday there, so funny you should bring that one up! Perfect fit too!!
    gruf likes this.
  21. mancdan
    mancdan Active Member
    475
    49
    What is the anti pinch control all about?
    I can confirm that holding unlock on the key fob for at least 2/3 seconds makes all the windows go down, and then back up if you hold the lock button down for the same amount of time. Very useful when we have that one week of warm weather as you can open all your windows as approaching the car to let some of the heat out. My 8 year old son loves this feature too, he even shows his mates on our street!
  22. Reesy
    Reesy Well-Known Member VCDS Map User
    3,639
    148
    As mentioned above, the mirror feature is only for cars with memory seats..
  23. dope
    dope alcoholic pervert
    199
    I was loitering in your forum - the TBA trick worked on my B6 1.8T 190
    At least I percieved that it did. It could be placebo.
  24. jdp1962
    8,036
    2,484
    Nox
    I've been asked by a colleague to ask you if the backdrop to that picture (it's a beautiful shot, by the way) is the Clune Brae near Greenock.
    Jeff
    EDIT: Said colleague has looked again, and asked me to withdraw the question, LOL!
    Still interested to know where it is, though.
  25. Steve220
    Steve220 Member
    234
    15
    I also found that pulling the handle on the door opens it. I was amazed. No longer will I use a brick!
  26. gruf
    gruf Member
    288
    14
  27. Steve220
    Steve220 Member
    234
    15
    Colour
  28. chrisa4quat
    chrisa4quat Active Member
    970
    I have just checked my Bose settings and found they have been changed already. Has anyone got the original settings so I can see the factory Bose and de Bose sound? Thanks
  29. NOZ
    NOZ Member
    208
    21
    Jeff its Broughty ferry castle in Dundee and thanks the photo came out well
  30. jdp1962
    8,036
    2,484
    Ahah, east coast rather than west. Thanks for that. I will let my colleague know, just as soon as he and his hangover return to work here in London after watching St Mirren win the League Cup at Hampden
  31. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    I have found that if you open the fuel cap thingy and fill it to the brim with Shell v Power, it mysteriously empties very quickly allowing you more room to fill it up....all over again! Great eh?
  32. NOZ
    NOZ Member
    208
    21
    yeah but what fun you had worth every penny lol
    Molnboman likes this.
  33. CHEZ
    CHEZ moderately amusing Supporter
    4,141
    815
    that little sun visor above the rear view mirror had me impressed!
  34. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    766
    I found mine two weeks ago, I have owned the car for 4 1/2 years :banghead:
  35. jdp1962
    8,036
    2,484
    At least you didn't take that long to find out what those rear side window elements were for . :thumbsup:
  36. wyliss
    wyliss Member
    286
    I'm sure thats a VAGCOM job.
  37. jdp1962
    8,036
    2,484
    What is?
  38. wyliss
    wyliss Member
    286
    Bose
  39. CHEZ
    4,141
    815
    well i have wondered........................................
    care to share?
    ***********EDIT**********************
    good old ask jeeves, that would be my radio aerial! DOH! silly me! :ohmy:
  40. sidibear
    2,319
    766
    Chez,
    I only found out about a month ago what the elements were for.
