Yet another MMI - Missing Data Question and solution wanted
coach May 17, 2012
  1. coach
    coach Member
    82
    Did the 5570 MMI update today (mine was 4420 so I needed Disc 1. Went without a hitch and only needed to run disc 2 once) and installed the 2012 Nav Disc. I have a question for other A6 users:
    What details have you got listed in your Car Info panel, looks like I don't have everything. My son has an older lower spec car than me and he has the Battery Monitor and I don't. I have from top to bottom
    Audi Parking System
    Background Lighting
    Central Locking
    Exterior Lighting
    Instrument Cluster
    Service Interval Display
    Vehicle ID Number
    Windows
    Windscreen Wipers
    To be honest I didn't look to see if I had Battery Monitor before the update but its not there now. Can anyone tell me what should be standard and if I have something missing how to get it back. I dont have VAG-COM and dont even know what it is. Can I get it back without this?
    thanks
    Mick
  2. coach
    coach Member
    82
    Anyone in the Northumberland area with one of these VagCom Thingies that could sort me out?
    thanks
    Mick.
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,637
    9,616
  4. elan2s
    elan2s Active Member
    343
    40
    No Battery Monitor on my 2010 A6 so expect it was "removed" at some point. I believe that with VagCom it is possible to switch on a "hidden menu" with additional features one of which may well be the battery monitor.
  5. coach
    coach Member
    82
    I've been in touch with someone local with VAGCOM but when I private message him now the messages dont show up in my sent folder so I don't know if he has got them. DO you know if there is a list of things that should or can be enabled?
  6. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Things that can be enabled in mmi 2g
    Hidden menu
    battery meter
    visual parking aid (if supported)
    drl
    oil level (if sensor present)
    VIM
  7. coach
    coach Member
    82
    I have a 2008 A6 2.7tdi Quattro Le-Mans. It has front and rear parking assist with rear view camera. Not sure if I can get what you say. What is drl & VIM? You need the VAGCOM to get the hidden menu to enable these things DON'T YOU?
  8. a6_chris
    1,883
    160
    Ah you wont get that, instead you have the camera.
    Daytime Running Light - If you have Xenon then you will already have these
    Video In Motion - If you have a TV Tuner you can keep watching when you are driving - by default the picture cuts out ~5mph
    Yeah you will need vcds to do this ;)
    Where abouts are you?
  9. coach
    coach Member
    82
    I have the Xenons so have DRL. Don't have TV Tuner (watch enough **** in the house without seeing it in the car too) ha ha
    I think I have both the camera and visual parking assist the same as the front warning.
    I'm in Northumberland, I've been in touch with Gary but he has not replied for a while, (obviously working)
    thanks for the feedback
  10. a6_chris
    1,883
    160
  11. coach
    coach Member
    82
    I PM'd Jonny yesterday but got no response, got not more response from gary3306 either. He seemed keen to try and help. maybe there is something wrong with my account for sending PM's or maybe they are both to busy. I'll see if I get a reply from either of them today, maybe I need to try someone else.
  12. a6_chris
    1,883
    160
    I noticed he was online this morning when I was browsing.
  13. coach
    coach Member
    82
    Still no reply from either of them. I don't wnat to pester them, if they don't get back to me I'll have to take it to the dealer to get what I want.
    thanks
  14. a6_chris
    1,883
    160
    Audi won't enable these for you as they're classed as a modification - if you're friendly with your service advisor and garage they just might if you persuade them enough
  15. coach
    coach Member
    82
    Do you know which ones I should have as standard (which ones I have lost) & which ones I could have enabled that I dont have. I cannot seem to find out which ones should be there from the start.
    thanks
  16. a6_chris
    1,883
    160
    You probably did have the battery meter before the update so this can be enabled again, just say it was lost when doing the upgrade.
  17. coach
    coach Member
    82
    How do I find out what I should have, I cannot find any documentation which says what should be standard. Doe anyone else have a 2008 A6 2.7tdi Quattro Le-Mans that can tell me what I should have enabled and what I could have enabled.
    thanks
  18. a6_chris
    1,883
    160
    Sure I just did tell you what you could have enabled??
    Battery meter was standard
    I'll tell you what was standard in my January 2008 car.
    From the top
    Audi parking system
    Background lighting
    Battery meter
    Central Locking
    Exterior Lighting
    Instrument Cluster
    Vehicle ID Number
    Windows
    Windscreen wipers
    ^^ standard
  19. coach
    coach Member
    82
    This is what I have
    Audi Parking System
    Background Lighting
    Central Locking
    Exterior Lighting
    Instrument Cluster
    Vehicle ID Number
    Windows
    Windscreen Wipers
    SO I've lost the battery Monitor.
    What else can I have enabled?
  20. a6_chris
    1,883
    160
    Yes you've lost the battery meter because of the update - get Audi or someone with vcds to re-enable it
    Tbh, only extra worthwhile enabling is the hidden menu as you have most of the other things anyway which i mentioned near the start
  21. coach
    coach Member
    82
    what do I gain from having the hidden menu?
  22. a6_chris
    1,883
    160
    Nothing except enabling the battery meter ;)
    Stay away from Bootloader if you ever enable Hidden Menu
  23. coach
    coach Member
    82
    If I can get one of the 2 guys I PM'd to reply I could arrange something with them but I've yet to get a reply.
  24. a6_chris
    1,883
    160
    ok, if you do get a reply, let me know and ill give you the instructions to enable the hidden menu and then battery meter.
    just out of curiosity - your a6 doesn't start nh57 does it?
  25. coach
    coach Member
    82
    No it doesn't. It was an 08 but it has a private plate on now. I've read that if you loose something from the menu it has to be relocated to another location in the structure of things. Is this true? its not just a case of re-enabling it.
  26. a6_chris
    1,883
    160
    Ah right, just wondering :)
    Nope, all you need to do is enable the hidden menu, find the battery meter, press the tick box and reset mmi - now the battery meter will be in the car menu.
  27. coach
    coach Member
    82
    Excellent. Does that apply to other stuff that will be there that I dont have enabled too.
  28. a6_chris
    1,883
    160
    Slightly different but whatever you need I will get the info for you.
  29. coach
    coach Member
    82
    I don't know what else in in the hidden menu so I don't know what else I could have. Is there a big choice? Is this Audi just been spitefull in keeping them from you?
  30. a6_chris
    1,883
    160
    Thats the only thing really to enable in hidden menu .. other things like beep on lock is enabled elsewhere which I can video if you like ;)
  31. coach
    coach Member
    82
    Beep on Lock?
  32. a6_chris
    1,883
    160
  33. coach
    coach Member
    82
    Doh!
    You get an audible sound when you lock the car doors?
  34. a6_chris
    1,883
    160
    Yep, watch the video i just posted
  35. coach
    coach Member
    82
    Excellent.
    I need to start a shopping list. What else is there available?
  36. a6_chris
    1,883
    160
    All I have enabled on my car is
    Hidden Menu
    Battery Meter
    Chirp on Lock
    You already have the rear camera so you already have the visual parking aid
    And you said you didnt want the video in motion
    Thats about it really!
    With the newer facelift cars you can do so much more like needle sweep, turbo gauge, oil temp, lap timer, passenger side mirror tilt - unfortunately none of these are avaliable on our cars
  37. coach
    coach Member
    82
    I dont have the TV installed so the video on the move doesn't matter. My son has an 07 s-line with the phone cradle in the consol but no bluetooth. Is it just a case of enabling it in his hidden menu?
  38. a6_chris
    1,883
    160
    Ah, I must've misread one of your other posts
    Is the cradle on the dashboard or under the centre armrest?
  39. coach
    coach Member
    82
    it's in the aarm rest. I dont have the cradle and my bluetooth works fine
  40. a6_chris
    1,883
    160
    Right, from reading different articles online, i think he might have bluetooth.
    get him to take the cradle off and it should see a few metal contacts when this is removed.
    now start the car and press TEL, it should say search for telephone or something similar .. try this
