Yet Another Fault Code Thread..
Reesy Feb 1, 2011
  1. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Hi, the EML came on about 3 weeks ago on my late 2000 1.8T, and the faults were:
    1. 16825 - Tank Venting Issue
    2.17544 - Fuel Trim System too lean
    Got them reset to see if they were a one off, and the light stayed off for 2 weeks and has now come back on, the above codes were back, as was:
    17705: Pressure drop between Turbo and Throttle Valve
    Just wondering if these were common and what people had done to rectify the problems.
    Any help would be greatly appreciated
    Reesyboy
  2. S3featesV9
    S3featesV9 Active Member
    1,032
    12
  3. <tuffty/>
    21,367
    3,932
    Vacuum leak by the sounds... prob the PCV pipe under the inlet manifold...
    Start checking all the pipes for splits...
  4. Reesy
    3,640
    148
    Cheers for the links S3feates, was trying to remember the link for ages.
    Tufty - do you think this could cause all 3, or just the top 2? The link says the third could be DV related, but it isn't fluttering, which i thought was the tell tale sign it was on it's way out. Correct me if i'm wrong though...
  5. S3featesV9
    1,032
    12
    no problem...hope you get it sorted soon! and let us know what it was in the end! good luck
  6. <tuffty/>
    21,367
    3,932
    I am pretty sure it will sort all the probs... the third issue can result from split pipes... the link assumes pipes are in a good state... sort the leak out first then see how you go...
  7. Reesy
    3,640
    148
    Thanks alot, will check a bit later on
    Does the PCV pipe part number differ for different engine codes, or is it a universal fit on all 1.8t's? Reason I ask is if i need a new one, I am unsure which engine code mine is
  8. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Engine code is stamped on the clyinder head by the cam cover
  9. Reesy
    3,640
    148
    Cheers dave, looks like I've got some fun times ahead trying to find the leak...
