yellow light - vagcom output
goslings Aug 12, 2009
  1. goslings
    goslings New Member
    have a yellow light on my audi TT 3.2L V6 DSG roadster
    this is the vagcom output
    Is is just as simple as a duff Lambda sensor that needs replaceing
    3 Faults Found:
    16814 - Catalyst System: Bank 2: Efficiency Below Threshold
    P0430 - 001 - Upper Limit Exceeded - Intermittent
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 - 001 - Upper Limit Exceeded - Intermittent
    16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction (Open Circuit?)
    P0030 - 004 - No Signal/Communication - Intermittent
    cheers
    Ian
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    It may not be a bad sensor, it could be a bad connection to the sensor. This is the PreCat sensor on the right side of the vehicle when viewed from sitting in the seats - (Should be driver's side for you Brits). Typical Sensor Locations
