Yaw sensor - Where is it?
djmotorsport Mar 9, 2008
  1. djmotorsport
    djmotorsport Member VCDS Map User
    78
    My S3 (2001) has an intermittent problem with ESP/ABS. Looking through the forum, it appears likely that the culprit is the Yaw sensor (1J0 907 657A). I've taken off the lower dashboard on both sides, but I cannot find the damn thing! Anyone know where it is?
    MarkyB has one for sale, so at least I know where to get one once I can find it :)
  2. benr
    benr Member
    819
    you sure its not the brake switch?
  3. HTC
    HTC Active Member
    3,428
    9
    Its attacjed to the side of the steering column, quite far down.
  4. MarkyB
    MarkyB Member
    109
    Hi,
    your best bet is to buy/borrow a VAGCOM and check which sensor is faulty, as there are couple of sensors that can cause the EPS/ABS warning light to come on.
    Here a couple of posts that may help
    Diagnostic tools off ebay [Buying a cheap VAGCOM, you'll need your own laptop!]
    http://audi-sport.net/vb/showthread.php?t=37739
    [Replacing the] Longitudinal Acceleration Sensor (G251)
    http://audi-sport.net/vb/showthread.php?t=38175
    * this is not the part that I have in the ForSale section, which is a YAW Sensor.
    Cheers,
    Mark.
  5. djmotorsport
    78
    If it was, what would be the symptoms?
    For me, the ESP and ABS lights come on at start from cold, and after about 10/15 mins, if I stop/start, they go out and stay out - occasionally come back on on bumpy roads, and the only way to clear them is to switch the ignition off/on. When the lights are on, you can spin the wheels in first and lock them under braking.
    Just managed to find the offending item (Thanks HTC) and get it out.
  6. djmotorsport
    78
    I'm lucky that I've got access to another A3 that I can swap parts with, but no VAGCOM. So, I'll try both of these sensors and see what's what.
    The power of t'internet - magic :)
  7. benr
    benr Member
    819
    not totally sure but with mine the esp and abs lights came on and it came down to a rear break light bulb not seated properly...
    thats what made me think its to do with the brakes although im no expert..
  8. S3_Pricey
    S3_Pricey Member
    302
    If it was the brake switch then you would have no brake lights. this happened to my A3 shortly after gettting it
