YAW sensor part numbers HELP PLS???
sanj_c May 23, 2013
  1. sanj_c
    sanj_c New Member
    19
    Hey guys,
    I'm after a bit of help!?
    I've had the traction light on for ages on my S3 2001 facelift. Took it to a specialist who said the longitudinal sensor needs replacing. He replaced it but the light is still there. He is now saying that it looks like a signal problem from the YAW sensor. There's no way I want to spend £500 on this sensor so i'm thinking of getting a second hand one. Does any one know the part number for the YAW please? I know the longitudinal sensor sits on top/front of the YAW.
    Also is this a sensor which you can replace yourself? Does is need calibrating? Is it located under the steering column?
    Any help would be much appreciated
  2. s3mad_dude
    s3mad_dude Noggies ruuuule!
    614
    79
    I was always under the impression the ESP sensors were located behind the glove box.
  3. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
  4. Gops
    3,198
    666
    You need to scan it again to see why it's still on..
  5. Hhubbyy69
    Hhubbyy69 New Member
    Having same problem, did you sort this? Im getting esp light come on flashing and brakes grinding then stays on permanently
  6. RickyB
    RickyB Audi S3 8V FL BE Silver Supporter Audi S3 Team Ara Blue
    66
    145
    33
    I had this a while back found it to be the one on the steering column. Sourced a second hand one and was then fine after resetting.
  7. Hhubbyy69
    Did it need coding or anything or just plug it in and sorted? If not howd you do it? Might go scrappy if its easy Thanks
