XS Power K04 Manifold for 210/225 S3
Welly Sep 8, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Morning all.
    I have taken delivery of an XS Power/Relentless K04 Exhaust Manifold for the S3 210 and 225. Basically, any car with the K04-022.
    Same goes here as did in my other thread http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/102665-email-xs-power.html. I will be reviewing this, giving XS Power some suggestions on where it can be improved etc, therefore making it a well worthy buy.
    Initial thoughts are good. Very well made, and nicely welded together. My main concern, as was always going to be is the turbo flange. One of the flange bolts holes would be very tricky to get to. And I mean very tricky indeed. I have a mate who is going to knock me up some studs to wind into the turbo for testing purposes and then I will go from there.
    I have managed to bolt it to the turbo to mock up the fitment. All the flange holes are spot on which is a good start.
    I will update this thread as things happen. Didn't have much working time last night as her indoors wanted me to watch Eastenders. Deep joy.
    Photos:
  2. badger5
    9,471
    1,988
    looks like a challenge that one bolt/stud fixing
    you tried it in situ onto a head yet welly?
  3. Welly
    10,696
    127
    Not yet, I was going to try it on one of your spares to see what fitment was like. When are you back anyway dude?
    And, more to the point, what are you bloody doing on here? :lmfao:
  4. badger5
    9,471
    1,988
    back saturday, back in w'shop sunday
    ... and i am sad.. cant stay away or switch off car stuff
  5. Welly
    10,696
    127
    LOL, I know that feeling. OK - will pop up and see you on Sunday for a natter about the above.
    PS. You're out of milk.
  6. Speedy Steve
    Speedy Steve Active Member
    1,258
    interesting know Bill has showed me the 034 motorsport manifold it will be interesting to see how this works out
  7. Welly
    10,696
    127
    Going to start looking at this properly tonight and see where we get.
  8. <tuffty/>
    21,140
    3,828
    I am at the unit until 4ish today mate and from 10 till 4 ish for the rest of the week if you wanna pop over..
  9. Broken Byzan
    13,237
    465
    Shiney mate, liking it.
    I see they slotted the one hole, at least that's easier. It's what i was going to do to fit one to mine before i bought a cheapo cast one instead.
    Nail it on mate, nowt to lose
  10. Speedy Steve
    1,258
    This is looking very tempting
  11. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I remember a tig art manifold like this... was a real ball ache to fit with the engine in situ,
    I remember the only wat realy was to fit the turbo to manifold, then mani to the head ... then the head to the car.
    That bolt on the flange involved some chopping and welding of a spanner to get a nut on. BUT it was a pain and kept coming loose.
    Hope this works out.
  12. Dani_B19
    9,252
    376
    Looks a good piece of kit, lets hope yoiu can work your magic welly as i think my manifolds cracked :(.
  13. Welly
    10,696
    127
    Good evening good peoples.... we have some developments on this.
    It is fit-able.
    Well, potentially at least. I have managed to fit the manifold to the turbo off the car with success. Not easy though. And not possible with OEM equipment.
    Lets start at the beginning. The issue with this manifold was always going to be one thing in particular. The turbo flange. Bolting the thing to the head should be easy by comparison to an OEM one as there is endless room to get hands/tools through.
    Permit me to demonstrate:
    This particular hole in the flange will be the hard one, as access is nil.
    Totally impossible to get an OEM bolt in here. There is no way it can be done. End of.
    As mentioned earlier in the thread, I had a good mate of mine (he's on here also but I don't know his name as he is new), George, knocked me up some CNC machined Stainless Steel studs for a mock up assembly.
    He produced the following (good lad :thumbsup:)
    Just the job for fitting this sucker.
    Studs are wound into the turbo flange, and then the manifold mated on top. These first attempt studs are actually a little shorter than they need to be. Between 3 and 5mm needs to be added to the top to allow the nut to clamp down to the stud properly. He is going to do me another 2 sets of 3, one with 3 mm added and one with 5 mm added and then I will decide what's best to use.
    Anyway - 3 M10 nuts required for this - the first 2 being easy to fit on and tighten. The third, being the one pictured above is a fiddle to get the nut on and threaded. However, it is do-able and you can also get a 17mm spanner in there to tighten the nut up. Tight as a gnat's chuff though. I will be 'manufacturing' a special tool for doing this, as I think it can be made easier with the correct bodge.
    At this point I think it is only fair to mention that XS Power's claim that the downpipes they supply (that haven't historically fitted with the OEM manifold) do fit with this tubular one as they stated.
    Here are some photos of the turbo and manifold bolted together properly.
    This is the one that is a bit of a biatch to get to....
    All points go.
    The only real way to test this is to use it and see what happens with prolonged use. Potential failure will be highlighted then.
    I will be checking the fitment to a 1.8T head on the weekend so will get back to you with that info.
  14. Welly
    10,696
    127
  15. Andrew@A.L.D
    3,877
    617
    Have you tried fitting the O2 sensor as this is very close to the standard manifold with the XS down pipe
  16. Welly
    10,696
    127
    Yep, there was enough clearance.
  17. Welly
    10,696
    127
    Does anyone know if you can get a high heat thread lock? Loc Tite's highest temp stuff is ~500 degrees.
  18. Broken Byzan
    13,237
    465
    I had one of those weld itself to my turbo and mani and blow through the middle, i had to scrape and file to get the residue off,lol
    Stuck a used OEM one ( as its all i had) and she is fine atm.
    But seeing you are going to be dropping it off biweekly to reweld, changing the gasket won't be a problem....LMAO
    Hows that silly expensive pipe? Fitted?
  19. Broken Byzan
    13,237
    465
  20. Welly
    10,696
    127
    Hopefully not..... :(
    But like I said, that's the only way to test it to be fair. Use and abuse.
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  22. ricko
    ricko Member
    45
    i have the same manifold on my a3, it's been on for about 6 months now i'll take some pic's for ya. the problems i found were like you said the one nut that you cann't get to. but i also found it moved the turbo back so i had to get new oil line's made up. oh and it gets bloody hot, i'll try and put some pic's up tomorrow
  23. Welly
    10,696
    127
    The same manifold on an A3? Is your A3 K04 equipped dude? Anyway, pics would be great if you don't mind.
    Impressed that you've been using it for 6 months without issue.
  24. badger5
    9,471
    1,988
    nordloc washers
  25. ricko
    ricko Member
    45
    i took some pic's for ya, i'll try and put them on after. yes it has got a ko4 on it, the only worry i have is like i said it gets very hot and there's lots of bits and bob in that area. i think am going to try and get it coated next summer, like i said you might have to get longer oil line's made up but am not 100% because your old manifold is nothing like mine
  26. Welly
    10,696
    127
    It'll be fine on the S3, it's designed to have the K04 as standard, where as your engine layout isn't.
    Pics still would be good though. :thumbsup:
  27. ricko
    ricko Member
    45
    well i know that now lol. I cann't work out how to post the bloody picture's cos i is well fick an dat. could i email them to you i think i can do that:wacko:
  28. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Create an account with photobucket.com then upload your images n it will give you an IMG Code then just copy n paste that on here.
  29. emery1990
    emery1990 Active Member
    1,068
    Did you notice any gains from the new manifold? From reading up about after market manifolds ( different car ive got but still probably the same on others) is that they take away torque from the bottem end and put it right up the top of the rev range, being good if you've got a race engine that revs high ? This is the reason im now selling my after market one and staying standard. On n/a that is, dont have a clue whether the same applies to turbo's though?
  30. ricko
    ricko Member
    45
  31. ricko
    ricko Member
    45
    I BLOODY DID IT:p i can now add computer skills to my c.v
  32. Gops
    3,198
    666
    "fluent with microsoft word, excel and an expert in paint":p
    Looks good welly, had a test drive yet?
  33. badger5
    9,471
    1,988
    how flat was your head flange on the one pictured?
  34. ricko
    ricko Member
    45
    the head flange was fine but i did have to skim the turbo flange. gops this is my engine bay not whelly's had it all in stalled for abit now
  35. badger5
    9,471
    1,988
    i know its your engin ebay not his mate.. his manifold is sat here hanging on one of my heads on the shelf ;)
  36. ricko
    ricko Member
    45
    this is getting confusing lol. i know you didn't think it was whelly's. the fella before you called gops said " it looks good whelly, had a test drive yet"
  37. badger5
    9,471
    1,988
    lol - very confused. (but I usually am)
  38. badger5
    9,471
    1,988
    how you have'nt melted any pipes yet is staggering..
  39. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    lol this has been a funny read since you joind in hahaha
  40. Welly
    10,696
    127
    LOL, WTF is 'Whelly'? lol
    Anyway, some issues have come to light with this - 5mm warp on the manifold flange makes this manifold unsuitable sadly.
    I will be getting in touch with XS and having a chat about it, see what can be done.
    Turns out the pipes are stainless steel, and very well made. The flange however appears to be cast, and is magnetic making it clear that whatever material it is, it isn't stainless steel.
