XS Power Downpipes & Manifolds
Welly Sep 20, 2011
Thread Status:
Not open for further replies.
  1. Prawn
    11,574
    3,546
    I'll be fitting mine in the 1st week of Jan Jim, so I'll let you know how simple it is! From memory, due to the shape of the manifold, spanner access is almost non existant to some of the bolts, so I'll have to wait and see how best to tackle it!
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    4 Rings did the job for me as they removed the turbo and fitted the new one.
    As far as I know they just used OE gaskets from Audi and I'm sure it's only the 1 gasket that you need. But I'm not 100% mate.
  3. Jimgrim77
    Jimgrim77 Member
    957
    21
    Thanks. Appreciate your help. I'm just weighing up whether to get stuck into the whole manifold, rods, head and hybrid experience.
  4. Jimgrim77
    Jimgrim77 Member
    957
    21
    Thanks westy.
    Very informative and lots to consider. I'd assumed, like any mod, that one thing very much leads to another and this is no different.
    I'd love to see the performance difference in the vehicle with all of the above in situ compared to mine.
  5. sportstractor
    sportstractor Chugger
    2,709
    I was always under the impression that it was a head off job. I'm tempted to do mine as mine manifold has a crack in it. I'm happy to have the head off and fitting a new headgasket etc, although I have done the timing belt a few times on other cars im not sure I'd be confident enough to do it on mine... Although massively tempted to give it a go.
  6. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    I have removed the manifold in situ and removed the head to access it needless to say if i ever have to remove it again i will certinally be removing the head to do it, a tubular manifold im sure will give you more room to work with between the runners than a cast one but i would advise still removing the head
    You could also find a tight one that draws the stud out with it which again will be a complete pita :thumbsup:
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    129
  8. Welly
    10,696
    129
    Anyone who says fitting one of these is a breeze, think again.
    Not an easy job by any means. However, it depends ultimately on how much you want that extra flow.
    So, what makes it such a pain? The arrangement of the holes on the Turbo flange in conjunction with the runners of the manifold simply.
    It is outright impossible to use OEM bolts to mate this, they won't work.
    Use 3 x K04 turbo/downpipe studs. Wind those into the turbo short end first from memory. Makes sure they're tight. Then, when manifold fitted, use 3 stainless nuts (preferably with Nordlock washers to stop them loosening) to bolt the tubo and manifold together.
    One of the nuts (top left of the three) will require a 'special' spanner to actually get to the nut at all. Trust me, it can be done.
    Mani fitted to head:
    'Special spanner'
    Et voila:
  9. Welly
    10,696
    129
    Manifold in use:
  10. Westy
    17,443
    1,105
    Cheers Welly.
    Sorry but I'm still a bit lost with what nuts and bolts are needed?
    As you know I've already got the XS DP and will soon be fitting the mani to a standard k04 turbo.
    I need to ensure I have everything I need before I do this job along with IE rods and large port head.
  11. Westy
    17,443
    1,105
    Also is it worth heat wraping the mani?
  12. patTTpoa
    patTTpoa Member
    793
    That's a good question! I'd also like to know
    Pat
  13. Welly
    10,696
    129
    OK, this what you should be aiming to do:
    Would into the turbo in the above pictures are 3 K03 (not K04 sorry - will edit original post) downpipe studs - part number N 907 678 01. Cost around £0.55 each inc VAT.
    I think those studs are M10 thread, so get some stainless steel nuts which mate them from the local hardware shop for pence.
    This way the manifold will slot onto the turbo. Does that makes sense?
  14. Welly
    10,696
    129
    Not really. I think it's arguable how long heat wrap would last on it, that video shows how hot they get. Also, it is very tightly put together, with very little gappage in between the runners.
  15. patTTpoa
    patTTpoa Member
    793
    Cheers, should the DP be done?
    Pat
  16. Welly
    10,696
    129
    Again, up to you. No harm in the downpipe being done. Don't use cheap heat wrap though, it turns to glass and falls off....
  17. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    My brother (ex mechanic) and a friend (Audi Mechanic) wanna try it with the head on. Who am I to argue its them who will be doing the work for beer tokens.
  18. Welly
    10,696
    129
    Fair enough, I say go for it. It's just always been easier IMO to take the head off. Less hassle, everything accessible. Less scrabbling around in the dark, at the back of an engine. :)
    Whatever works :)
  19. Westy
    17,443
    1,105
    That crystal mate thanks. What's different with the standard turbo bolts then?
  20. Welly
    10,696
    129
    When you get the mani mate, you'll understand immediately.... Trust me!
  21. Westy
    17,443
    1,105
    Ok mate. I'll order the bolts ;)
    My biggest nightmare is getting everything apart and not having the right parts to get it back together again straight away.
  22. Welly
    10,696
    129
    Yep, I can understand that. OEM bolts will not work. Simple.
  23. StaceyS3
    2,505
    502
    Dont forget that i got you some bolts and washers from bill ;)
  24. Westy
    17,443
    1,105
    So the part number you quoted earlier, is that for the OEM bolts?
    Edit:
    I've just remembered that the standard bolts go down through the top of the mani and scre into the turbo thread.
    I've also just bought 3 new ones from Bill :banghead:
  25. Westy
    17,443
    1,105
    Yep. The nordlock washers will come in handy but the bolts are useless :)
  26. Welly
    10,696
    129
    Part number above was for the studs in the picture, wound into the turbo.
  27. JtotheD
    JtotheD Active Member
    907
    26
    should be getting my 3"dp and sports cat fitted tomorrow. I'm just hoping the gaskets arrive in time. If not the place doing it said they can fabricate some as the custom build exhausts..
  28. benh999
    benh999 Member
    233
    I see the buy it now on eBay has magically gone up from £380 ish to £450 now :-/
  29. Matt82
    Matt82 Active Member
    2,365
    welly, i saw a yellow s3 on ebay and thought of your bumble bee. good to see youre still pioneering this stuff.
    woodyS3 likes this.
  30. Chlippo
    Chlippo Member
    679
    15
    I am installing the decat downpipe and the manifold at the moment. will post pictures on a new thread once im done.
  31. Prawn
    11,574
    3,546
    Ordered my decat DP a few days ago :) should turn up today.
    Can't wait to get it all fitted!
  32. sambryant
    sambryant stage 2+ mk2 seat leon cupra
    167
    12
    not mine by any chance :)
  33. badger5
    9,540
    2,017
    westies is another in mind.. whichever comes first we will see
  34. Westy
    17,443
    1,105
    Easter holiday will be the date the XS mani will be fitted but I'll then need to come across to see you again for some dyno action.
  35. sambryant
    167
    12
    guys i have been in contact with usa XSpower (relentless) and i can get these downpipes and manifolds alot cheaper. the new manifold will cost $300 shipped and dp with decat $325 or with sports cat $375.
    these need to be bought through me to get these prices.
    i have also created a facebook advertising this. Log in | Facebook
  36. sambryant
    167
    12
    i may sneak in there before. im hoping this feb :)
  37. superkarl
    superkarl MAN OF STEEL
    9,553
    2,452
    Sam you will have to pay customs and import charges. So prob wonnt be cheaper at all. And tbh, theyre cheap enough.
  38. sambryant
    167
    12
    decatted down pipe is around £150 cheaper and sports cat is £210 cheaper :)
  39. Prawn
    11,574
    3,546
    ARGH! SCN are invading, another one! Hey Sam. Welcome.
    For those who are genuinely bothered about flow, I noticed something on my XS downpipe this evening:
    The flange on the end of the downpipe, is 3'' where it joins onto the decat section:
    But then the flange that it bolts to, leading into the rest of the system, is only 2.7'' across:
    So it gives an instant 0.3'' step reduction in the system.
    THe pipe going into the flanges on each side is genuine 3'', but for some reason the second flange has a smaller hole causing a restriction to flow.
    To get around this I'm going to get my dremel out and port out the smaller flange until it matches the bigger flange. Probably a horrible job, but I think it'll be worth it.
    Also worth mentioning that the holes in the flanges are slotted too, so any misalignment when joining them together could also cause a nice stepped restriction.
    Seems a waste to sppend all that money and not fix a few little issues like that, shame XS didn't address these issues though.
  40. sambryant
    167
    12
    unless you have a 3" catback then its not worth doing.
Thread Status:
