  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    thinking of putting xenons in my a3 the single bulb sort not bi ones do i need an adaptor lead does any body noe any one in uk that does this lead ?
    thanks
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    The standard xenon's are a direct fit, you just need to use vagcom to tell the car it has them.
  3. tdi-man
    1,783
    64
    oh right thats good news then i have vagcom ..can you adjust the height of them with vag com as im not installing the auto levelers
  4. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    dont they pop the wiper motor?
  5. A3Bash
    A3Bash Member
    169
    I think only fake HID's pop the wiper motor.....hate them with passion
  6. tdi-man
    1,783
    64
    no thats the aftermarket hids....
    i just bought a set of xenons so need some help any body local with single xenons that i can plug mine into to set them to mot mode ......
    thanks
  7. Khufu
    5,704
    31
    You cant adjust the height using vagcom (even if you can?) as you dont have the module that controls the height installed. The module also wouldn't work right without the leveling motors installed either. There will be the normal adjustment screws, hopefully you can get enough adjustment off of those. I guess you could line car up against a wall and mark off where the lights line up to including the break off point and then when you fit new ones make sure they line up up/down & left right.
  8. tdi-man
    1,783
    64
    ok many thanks so i need to plug them in to someones car to adjust to normal height and unplug them while there on....then refit to my car and manual adjust ?
