Xenon's on S3's not very bright ?
imported_roydonaldson Dec 31, 2004
  1. Hi there,
    I've got a '53 S3 with Xenon lights on it. I've now had it in Glasgow Audi twice to have a look
    at them as they just don't seem to be very bright. They've had it on their MOT test kit and say it's all fine, the electric motors are ok etc.
    Are the Xenon's on the S3 just not very bright ?
    I'm asking, as having had A3s with normal lights, the Xenon's don't seem a lot brighter and my wife's TT with Xenon's seems brighter ???
    Thanks,
    Roy.
  2. Masterm8fo
    Masterm8fo Warmonger
    342
    have same thing on my A3
    think i might change the bulbs and see if that helps
  3. The Slug
    The Slug Active Member
    1,869
    Only way to check is with another S3 with same lights.
    I got A3 with normal lights, pretty bright too, can see the road at least, lol, but TT lights do seem to be very much brighter.
  4. RacingTeatray
    RacingTeatray Freezing in Moscow
    249
    Normal A3 headlamps are rubbish so it stands to reason that xenon S3 headlamps (being the same basic design) will be rubbish by xenon standards.
    I put those Phillips 50% brighter bulbs in my (non-xenon) headlamps eventually out of desperation and it made a vast difference.
  5. jediknight
    jediknight Member
    835
    so is there any way to improve the xenon set up? can you get brighter xenon bulbs? they would cost a fortune though ..
  6. The Slug
    1,869
    Can u actually change the normal A3 round globe type bulbs then?
  7. [ QUOTE ]
    RacingTeatray said:
    Manly-looking headlamps?!
    Weirdo!
    [/ QUOTE ]
    Hey Happy New Year to you too. Maybe you should get out more often and lighten up, I was only joking about the headlights hence the Instant Graemlins after what I had written.
    P.S. Weirdo.
  8. RacingTeatray
    249
    LOL!
    I was just highly amused by the idea that a headlamp could be "manly"!!!!!!
    I shall look at them in an entirely new way from now on.
  9. Khufu
    Khufu Well-Known Member
    5,704
    31
    I agree with Highlander1, and its not because he's Scottish too /ubbthreads/images/graemlins/lol.gif I prefer the way the dip bulbs are on the outside and so make the car look wider. I believe they are the other way round on the facelift.
  10. jediknight
    jediknight Member
    835
    Did anyone have an answer to this question then??
    ta
    [ QUOTE ]
    jedi-knight83 said:
    yeah what style of bulb is the S3? H1, H4, H7? they only do 6000k on that site.
    Cage... where did your friend get his 10000k ones?
    getting my xenon motors changed mid jan so would like to have all the bulbs ready so i can change them over when the lights are out.
    Side lights = 501 type
    xenon = ??
    Main = ??
    thank you in advance
    [/ QUOTE ]
  11. monty77
    monty77 Member
    391
    [ QUOTE ]
    ta
    [ QUOTE ]
    xenon = ??
    Main = ??
    [/ QUOTE ]
    [/ QUOTE ]
    According to www.powerbulbs.co.uk
    low/dip = H1
    main/full = H7
    ..not sure if the H1 applies to Xenons too though, perhaps their bases are different altogether?
    To re-iterate though - 10k HID bulbs will be DIMMER than the std ones (4.2kish) .. i.e. give out less visible light. Should imagine they're very blue/purple in colour too.
    HTH
    Adam
  12. The Slug
    1,869
    Im confused, lol.
    I have a 2003 A3 with standard headlights (clear polycarb) with the eyeball looking light, what changes or what do i need for brighter lighting? Thanks
  13. monty77
    monty77 Member
    391
    [ QUOTE ]
    The Slug said:
    £300 is that fitted?
    [/ QUOTE ]
    Nope, but it's fairly easy DIY job. I did it on my last car. Kit comes with loom, you just need to plug it all in and mount the ballast(aka starter) unit somewhere. Would be pretty easy on the A3 I'd imagine...
    Adam
  14. monty77
    monty77 Member
    391
  15. The Slug
    1,869
    Thanks Guys! Really appreciate the info.
    So these bulbs(H1) Orsam thingys , r they similar to normal filament bulbs, just behind a ball?
  16. Masterm8fo
    342
    think i will go with the osrams also!!
    dont think i would recoup such an expenditure on HID kit when i come to sell the thing (poss early next year)
  17. Cage
    Cage Member
    95
    [ QUOTE ]
    The Slug said:
    these aqua blue bulbs then where can i buy them from?
    [/ QUOTE ]
    The company is called Auto Bulbs Direct (www.autobulbsdirect.co.uk). You will need to call them, as the bulbs are not advertise on their website.
  18. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    You could always remove the kit and take it with you, assuming new car is H1 fitment also /ubbthreads/images/graemlins/wink.gif
    Adam
  19. T11OM F
    T11OM F Fearon
    151
    Why can this thread be like 2pac, and be resurected??
    Did anyone find the cure to this problem?
  20. steve1975l
    steve1975l Member
    595
    My S3 just failed the MOT today...Xenon lights not bright enough.
  21. T11OM F
    T11OM F Fearon
    151
    Seriously.. What you going to do about it?
  22. steve1975l
    steve1975l Member
    595
    Yeah I thought they were winding me up. I am going to try a new battery and check the alternator tomorrow.
  23. T11OM F
    T11OM F Fearon
    151
  24. sitrials
    sitrials Member
    872
    mine failed today but for alignment of the headlight the leveling motor has been ordered as i vag comd it and the diver side doesn't move where the passenger side levels itself on output tests.
  25. mk1chopper
    mk1chopper Missing the S3
    1,092
    Mine failed on alignment, sorted now but i do think that my xenons arnt that bright, i recon my gf standard clio head lamps are brighter, my sister 182 xenons are a lot better than my S3 i have a pre facelift s3 (if that makes any differance).
  26. steve1975l
    steve1975l Member
    595
    I am sure my battery has had it as they use to be brighter. I think it failed as it was cold morning so heated seats were both on, heated rear window on and the MOT guy had just started up when he did the test.
  27. Lenny Benford
    Lenny Benford snowed under
    167
    I had this on my S3 changed the bulbs to 6000 kelvin (i think) and they are REALLY good. Got them from http://www.hids4u.co.uk/default.asp give them a call they will sort you out.
  28. T11OM F
    T11OM F Fearon
    151
    Steve.. What have you done, are they any better?
  29. steve1975l
    steve1975l Member
    595
    Changed the battery and it is better but still not great...got the MOT certificate though.
  30. T11OM F
    T11OM F Fearon
    151
    Im tempted to buy new bulbs, but reading up on peoples views on here, and i think it might be £35 down the pan
  31. steve1975l
    steve1975l Member
    595
    Bulbs are a bit too expensive. When I go out in the gf's car and go back into mine I think they are great.
  32. T11OM F
    T11OM F Fearon
    151
    How do you adjust the level of them??? Is it manually?
