Xenons not self levelling.
S3 Harj Oct 21, 2010
  1. S3 Harj
    S3 Harj Member
    Changed the xenon bulbs and In pretty sure they're not self levelling. How can I correct this?
  2. <tuffty/>
    21,965
    4,239
    The motors are known to go wonky or you could just need adjusting and resetting...
    There is a how to somewhere in the 8L section explaining how to remove the motors and 'clean' them hopefully sorting a potential prob but if you download this pdf it has a section on realigning and resetting the xenons on page 30..
    www.wikitt.org/wikiTT/images/f/fc/TTweakers-Guide.pdf
  3. S3 Harj
    S3 Harj Member
    Thanks mate. Although i dont have a VAG.COM to sort it. :(
    Should i take it to a dealer? DO you think they'll charge?
  4. Mr.G
    Mr.G Well-Known Member Team Sepang Audi S3
    1,434
    228
    I've unplugged mine and many many others have too. As long as they are setup by an MOT station and levelled i'm sure it'll be ok. Mine got through an MOT with the motors unplugged.
    G
  5. <tuffty/>
    21,965
    4,239
    What do you think ;P
  6. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    For the record you will need the basic version of VCDS (formerly VAG COM) for this, not just the free version. The free version allows you to do the first couple of points but won't let you set and learn the new positions. I've now thrown a code (035 or something), so I need to get on and purchase a VCDS activation code for $99.
  7. Dani_B19
    9,468
    435
    Well hurry up and do it, if it works with a ebay cable then i can do it too :) haha.
  8. S3 Harj
    S3 Harj Member
    Lol.. silly question i know.
    Got it booked in at a specialist. Thanks for the info guys
  9. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3 Manual
    193
    15
    Mr. G where is the plug for the auto levellers?
  10. Mr.G
    1,434
    228
    The plug is located on the inner side (nearest the grille) of each light housing. Toward the top if I remember correctly.
    G
  11. JD09
    3,096
    46
    Lol, on it Monday night buddy.
  12. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,368
    909
    Have you tried adjusting them with the white screw above the lights in the engine bay, you will need an allen key for it, this happened on mine, and I think they just go stuck, once I did it, they were ok after that....
    Might be a quick and easy...not to mention cheap fix.
