Xenon Side Light Replacement
BigG Mar 28, 2009
  1. BigG
    BigG Member
    31
    Ok....
    I've read all the posts that a search returned and am pretty sure I agree with one.
    Stating the sidelights if you have xenon's are NOT 501's.
    I unfortunately read the posts after a trip to halfords, were I picked up some 501's.
    Managed to get the bulb out (without removing the headlight), but could not get the bulb out of the holder.
    I suspect it's because the H6W bulb does not pull out ???
    From the looks of it you need to pop it out with a small screwdriver behind the bobble on the bottom part of the bulb.
    But would really appreciate some clarification on this one.
    Also, anyone know where I might be able to get the H6W bulb from tomorrow in or around Northampton ?
    Halfords don't appear to stock the H6W bulbs.
    Graeme
  2. bubstar
    bubstar Member
    550
    The H6W is a bayonet fitting, you need to twist it 90° anti clockwise and pull to remove from the holder. They can be very tight though!
  3. BigG
    BigG Member
    31
    Thanks.
    I finally got a 6W bulb from the 2nd halfrauds here :)
