Xenon Power Wash
AshA4 Aug 16, 2012
  1. AshA4
    AshA4 Ash
    285
    Guys,
    Quick Q, done a search and cant find anything.
    When the washer fluid gets low in the reservoir and the "refill" light comes on, there is still water coming out of the windscreen jets but the xenon wash will not fire, fill the washer bottle up and they fire again.
    So question is... is that by design?
  2. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,960
    721
    I would assume so... Being able to see out the windscreen is probably more important than having clean headlights if u only have a limited amount of wash left... ;)
  3. NHN
    29,596
    1,782
    Yes thats normal, not enough pressure there to push the caps up as its pressure based mate, just fill up & few uses will restore functions :)
    Possibly in vcds (8P does) you can code the washers not to be used so often as the windscreen does, to conserve water & tbh they dont need washing everytime you do screen with lights on, also you can set the time beore they will activate, so if its a quick spirt of water on screen then it wont activate headlight washers aswell.
  4. AshA4
    AshA4 Ash
    285
    Cheers guys, thought as much :)
  5. Bracer
    Bracer Member
    49
  6. Soot1e
    Soot1e Active Member Team Navarra Audi S4 Audi Avant Owner Group
    223
    79
    Default is every 5th windscreen wash. Headlamp wash will also occur if wiper stalk is held in windscreen wash position (with lights on) for longer than 2 seconds.
