xenon look fog lights
Leaky Lloyd Sep 28, 2010
  1. Leaky Lloyd
    Leaky Lloyd Member
    293
    right dudes,, allen was kind enough to post a link to the xenon look full beems he has fitted to his motor
    but im wanting some similar for the fogs aswell then all my front end lights are finished
    but i dont know what rating i should be getting?????
    all i know is they are h11 fitments can anyone help on the power rating please?????
    and can anyone reccomend a nice clean set!
    not bothered about the led ones either before anyone asks!
    cheers big ears!
  2. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,926
    199
    There are loads of xzeon look h11 bulbs on the bay, you currently have 55w so it deoenda if you want to try 100w i have just ordered a set so will post a pic wgen i get them
  3. mattyboyc
    1,926
    199
    There are loads of xzeon look h11 bulbs on the bay, you currently have 55w so it deoenda if you want to try 100w i have just ordered a set so will post a pic wgen i get them,what you using in the main and full beam ones now,the same as Allen?
  4. Leaky Lloyd
    Leaky Lloyd Member
    293
    mains are hid's mate,, gunna get the ones allen posted for the high beems,,, got 9led side lights just want some fogs,,
    will 100w be ok,, not get too hot i mean?
  5. mattyboyc
    1,926
    199
    I reckon 100w should be fine, obviously depends how long you have them on for,i don't use minw as fog lights although i can if i want they are linked to the full besm through a relay so can either be used as extra spots or conventional fog lights so 100w will be ok for extra spots but can't see them being alot of good in the fog as they will be too bright, if it's purley a colour match you are after the leds are great just the light output is ****, i have 4500k hids ditted so will order some of the 100w main beams you mention
  6. mattyboyc
    1,926
    199
    Please excuse my poor spelling, i can't get used to the small keypad on the iphone
  7. BahnStormer77
    BahnStormer77 BahnStormer
    2,771
    58
    Not an exact match, but here's mine: OEM Xenons and I think the fog bulbs are Osram Nightbreakers - I can check tomorrow.
    I tend to only use my fog swhen it's actually foggy - I was more interested in the Xenon+sidelight match.
  8. mattyboyc
    1,926
    199
    Whats the light output on the nightbreakers like?i have looked at these and they have a decent write up for a 55w bulb
  9. quattrojames
    14,050
    575
    I've got them on mine, they're not bad, certainly better than the standard 55w bulb. Quite yellow compared to my 6000k HID's and LED's though. As we've mentioned though, A4 fog lights aren't exactly bright at the best of times!
    I know I've got 100w's in my mains, but personally I wouldn't fit them to my fogs. The mains are rarely on for much more than a few minutes at a time, whereas the fogs could potentially on for a lot longer on a foggy journey.
  10. Shane-Ireland
    Shane-Ireland Member Team Ibis Team V6 Audi S3 quattro Audi A4 Audi Avant Owner Group TDi
    270
    22
    Where did you get the sidelights from? any links - a good match.
  11. Leaky Lloyd
    Leaky Lloyd Member
    293
    will xenon looks give bulb out errors , or do they all work ok ?
  12. quattrojames
    14,050
    575
    Fog lights aren't covered by the bulb out warning.
  13. Leaky Lloyd
    Leaky Lloyd Member
    293
    what about main beams?
  14. quattrojames
    14,050
    575
    Hmmm good question - I don't 'think' so no. Either way a conventional halogen bulb shouldn't trigger it.
  15. defsix
    defsix Member
    181
    I'm will be trying these Fogs 55W and 100W fulls. Someone else on the forum had these as fulls and they matched the HID's he had.
  16. dipteshr
    dipteshr New Member
    I've just upgraded the fogs on my A4 B8 from the standard yellow ones with MTEC 4350K H11's and I have to say they're a good match. They are available in the UK and dont cost as much as the Hoen imports. I would suggest anyone looking to upgrade the fogs who doesnt want to mess around with resistors and wiring to use these.
  17. vr6gordy
    vr6gordy Well-Known Member
    2,773
    180
    Errr yes there are
  18. vr6gordy
    2,773
    180
    Just fitted some of these bulbs in my fog light and the lense is red hot to touch guess there's no air pushing on it to cool it down .. Will they be ok the wire isn't getting hot witch is good but worried about the fog light getting very hot
  19. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    I had them in mine for about twelve months without any issues before switching to yellow bulbs (as I always do in the darker winter months) to match my yellow dipped beam bulbs.
    As for night breakers, I put them in my dipped and full beam when I first bought my car, and I have to say I didn't notice much difference at all to the standard dipped bulbs that were in there.
  20. vr6gordy
    2,773
    180
    In your fog lights ???
  21. Jimmy TDI
    1,320
    262
    These are what I have in my fogs through summer
  22. vr6gordy
    2,773
    180
  23. Jimmy TDI
    1,320
    262
    I honestly couldn't tell you as it's not something I ever thought to check.
  24. john777w
    john777w Active Member
    647
    85
    You can get LED H11's which will give you the white light your after!
  25. Jimmy TDI
    1,320
    262
    Kinda needed my fogs this morning, and after an hour driving my fog light glass is just warm. This is with my yellow H11, not the mtek, but these are supposed to have the same increase in power (55w-100w) as the mtek.
  26. mattyboyc
    1,926
    199
    I have used led in the past, the look is great but the light output is ****, I am just about to purchase some from T8ups as they come with great reviews.
