Xenon Lights Retrofit into 8p2 A3
8385HJ Dec 18, 2011
  1. 8385HJ
    8385HJ Member
    101
    basically i want to retrofit xenons into my car,
    what is a procedure?
    i know a different connector will be required i have found one that goes between the standard loom and xenon headlight for £40.
    Obviously i will need the headlights, i have found a set but the passenger light has a crack, can the outer cover be replaced??
    Also will they need to be coded?
    Any help will be greatly appreciated.
    Hussayn
  2. Ash187
    7,450
    712
  3. N8
    17,163
    718
    Headlight washers and Levelling also if you want it done properly. NHN is the main for the retrofit.
  4. 8385HJ
    8385HJ Member
    101
  5. 8385HJ
    8385HJ Member
    101
    Thanks N8 i will get in touch with him
  6. N8
    17,163
    718
    It'll be the best thing you ever do for your car. Getting Nigel involved :wub:
  7. c_w
    c_w Well-Known Member
    1,163
    87
    Don't worry too much about the levelling and washers, both massive wastes of time and money IMO. Had a Porsche Panamera following me on the motorway - the lights were pretty blinding, extremely bright, brighter than the norm for HID, it was almost as if the level was too high. What I'm saying is properly aligned a3 OEM xenons are fine and that even with genuine factory fitment does not guarantee non-dazzling lights.
  8. Farhan
    Farhan Active Member
    1,234
    57
    ash (itwasntme) fitted my bixenons, Quick service, Fitted me into schedule very quickly so no waiting around. Very reasonable aswell would recommend him.
  9. 8385HJ
    8385HJ Member
    101
    Having read many of his posts im quite sure it will be! :)
  10. 8385HJ
    8385HJ Member
    101
    Fair play mate, the only issue i really see is come MOT time it will cause a problem which is something i don't really want
  11. 8385HJ
    8385HJ Member
    101
    Thanks Farhan i will get in touch with him.
