Xenon light adjusters
Crazypete00 Apr 29, 2012
  1. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
    Hey, I have the common issue that the white clip in my light has broken, not too fussed because I can sort that. However on the opposite side light the clip is fine but the motor that's meant to clip into it doesn't reach the clip. I tried pulling the white adjuster out but it doesn't extend, any ideas?
    I also need a new motor any idea how much they are?
  2. RobMac1985
    RobMac1985 Member
    45
    i have got 2 levelling motors.
    pm me and can talk about price and sending them out if you want them??
    thanks
    Rob
  3. ant schof
    ant schof Member
    163
    HI mate ,
    You can actuate the levelling motor with a 9volt battery . If you disconnect the plug and remove the cover 2 or 3 tabs on the back from memory , you'll see three metal contacts . Taking a 9v battery with a live and earth lead to each of the outer prongs , easier with crocodile clips attached . Hold them on for a few seconds and you should see the ball end of the motor move in or out . To change direction of movement simply reverse polarity . should get the motor to the required position . Ideally you need vag com to to set up the correct position once fully installed . Hopes this helps .
    Ant
  4. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
  5. Crazypete00
    495
    61
    Thanks both for the reply,
    @ voorhees - already thinking of putting my name down for those, I have a clip that is very similar that I need to try first.
    @ ant - will try the 9v battery on it, I also have vag com so once I repair the other side I will set it up with vcds.
  6. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Hi
    The adjusters can be a pain to get back on to the clip some times.
    Try removing the back off the head lamp and gently pulling the reflector/clip towards the adjsuter arm as you rotate and twist the adjuster to get it to slide in to the clip from one end.
    Liam
