Xenon Level Sensor Rod Replacement?
coyle Dec 7, 2010
  1. coyle
    coyle From Show... to GO
    435
    hey guys, got the factory fit xenon's on my S3, and looked underneath, and on the passanger side there are two level sensor rods, one at front one at back.
    the front one is bent, but not buckled, so im not sure if thats how it's supposed to be? or should it be straight?
    and the rear one is snapped completely, so i need to know where i can get a replacement?
    i think its affecting the headlight aim, as the lights are very low aimed, they dont light up much of the road infront of you, which makes sense if the rear rod is snapped.
    any help much appreciated, cheers Jon
  2. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    This is weird, I've literally took a picture of mine just then as it's bent, because someone posted there lights being low. This is likely the problem. I'm just going to straighten mine out. As for the other you should get one from Audi. Hope it's not much
  3. coyle
    435
    yeh, but i read in another thread that it should have a bend in it, but cant find that thread so wanted to confirm it.
    i want to get the back one sorted though.
    and may then have to adjust the headlights manually if there still as rubish
  4. <tuffty/>
    21,874
    4,201
    The front rod is meant to be bent... don't try and bend it straight...
  5. coyle
    435
    I thought so, i hope karl reads this in time haha
    just need to find a rear one now!
  6. superkarl
    9,610
    2,481
    Ahhh cheers for that couldve made a big mistake there.
  7. superkarl
    9,610
    2,481
    I'm stumped then. When I turn the car on they raise up, but moving along I can watch them go down. I haven't checked the back arm yet though
  8. coyle
    435
    could be dodgy motors then, could disconnect them and adjust the lights manually,
  9. <tuffty/>
    21,874
    4,201
    Is it the arm of the sensor or the actual rod? the arm is easy to break if you are not careful when changing the springs on the back (which if yours is broken is how I suspect that happened as its not a part that breaks without human intervention)
    Plausible, a scan of faults codes would also confirm this as I am pretty sure a fault code will be thrown for this..
    Another common fault is the headlight adjustment motors... they stop working and the headlights aim low...
  10. coyle
    435
    from memory its the rod which is top to bottom. not the arm which the top attaches to.
    i'd need to check again to be sure, as i just noticed it wen it had my sump off, so didn't give it a huge ammount of attention.
  11. coyle
    435
    does any one have any idea of what the correct term for the part is? it would help to know what it's called when searching haha
  12. superkarl
    9,610
    2,481
    im guessing the rod is part of the 'xenon level sensor' assembly
  13. S3KO4
    S3KO4 Member
    850
    My front one is completely broken, so I don't get any of the auto adjust when I get in the car. however when the tank runs low on fuel the left beam drops massively this affects the hi beam as well :( I have used Vagcom on it and I managed to move them up and down. which is a nice bit of kit :)
    I think they are expensive, second hand around 50-70GBP for each one and probabily double that for new.
  14. coyle
    435
    surely because its just my rod thats broke, and not the arm, i would just weld a tube/sleeve over it?
  15. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,537
    314
    Old thread revival but I'm changing my front rod level sensor as my old one was snapped managed to get it fitted but can't see anywhere where the rod attaches any know where it goes?
  16. nobbybonez
    nobbybonez Active Member
    220
    49
    are both sensors required to get levelling working?
  17. Tj 0785
    1,537
    314
    Yeah it uses front and back to work out the level angle of the car so the headlights don't point to far up and blind on coming drivers or point to far down and not light enough road
    Plus think their a mot failure
  18. Stuart B
    Stuart B Well-Known Member
    1,935
    351
    some previous owner junked my xenons and replaced with normal bulbs and manual adjusters didn't notice until I replaced the rear leveller - the front one had been cut off totally. I don't believe I have the washers in the bumper either. It certainly makes for a headache when driving fast at night with no street lights - I reckon I get 3 meters visibility with the lights on main beam :)
