Xenon issues
estwing Nov 22, 2010
  1. estwing
    estwing Member
    55
    Right, i have the s3 headlights fitted to my a3 but there is a issue.
    Turned them on for the first time tonight, and they are poor. They are really dim, plus they dont send any light on the road.
    Does any1 know what the problem is? fuse? or is there more to it?
  2. NHN
    29,331
    1,716
    Care to elaborate a bit like were these retrofitted or on car from new?
  3. estwing
    estwing Member
    55
    they have been fitted when the car was made to be a s3 replica
    the light on the dashboard is telling me that i have lights out, both main beams dont work, and now when i have put my dipped on tonight my lights are really really dim, especially considering they are xenon
    does this sound like a big job?
  4. NHN
    29,331
    1,716
    Without knowing the car cant say for sure, certainly hasnt been wired properly by sounds of it.
  5. estwing
    estwing Member
    55
    hmmm, well i am taking it in to get the alarm checked this week so i will get them to look at that aswell.
    the side lights work fine, just the xenon (projectors) and the main beam.
  6. NHN
    29,331
    1,716
    Well it isnt plugnplay with headlights, wiring has to be changed & modules changed/added to make things work along with actually coding the car for these options.
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    sounds a can of worms to me!
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    sounds like theyve just been plugged in not wired in with the auto levelling system and modules to me, this is why you do a conversion properly and why mine took so long ;)
  9. c_w
    c_w Well-Known Member
    1,163
    87
    I find my xenons (genuine Audi) to be not that great, they don't seem to have the sharp brightness of those on the newer TT/A5s etc.
  10. smudge_don
    smudge_don Active Member
    2,944
    Newer lights are going to be brighter than older ones....plus the S5's and other newer models have 6000K bulbs, hense why they look a bit crisper and give off more light
    Try changing the bulbs over to some fresh ones, and maybe consider getting a better colour such as 6000K. Takes away the yellow tint from the standard xenons and also gives you a better view of the road
    I actually have 8000K which gives a slightly blue tint, but really lights up the road at night
  11. NHN
    29,331
    1,716
    Given the 8P is now 7 years old, the xenons are same, the bixenons are 4-5 years old, even the current drl led style is now 3-4 years old, along with developement aswell probably thought up & agreed to use a certain part long before release, newer cars obviously have newer tech therefore its more than possible this is the reason why they're better.
  12. smudge_don
    2,944
    There's an echo in here ;)
  13. NHN
    29,331
    1,716
    Nah you read my mind lmfao
  14. smudge_don
    2,944
    Impossible
    My mind reading capabilites don't stretch across Europe
  15. c_w
    1,163
    87
    Yea I may try some new bulbs at some point BUT the lights came off a low mileage S3 (they're the late bi-xenon units and from a 2007 car). I would say a friend's mk4 Golf R32 look "crisper". My brother's '53 A4 which has the factory projector headlighs but an aftermarket HID kit fitted has really bright , crisp looking lights. It's almost as though the projector in the A3 headlight is too opaque.
  16. pi quattro
    pi quattro Member
    127
    Hang on
    I have xenons on my 07 tdi quattro and love them, what would be the standard rated buldb for that? 6000K? can i get better ones than that, if so where and how much?
    theyre the ones that nod up and down when you start up, self leveling.
  17. smudge_don
    2,944
    I'd imagine the factory fitted ones are 4300K, the later 09 models seem to have 6000K from what i can tell
    So i'd get some 6000K, maybe some 8000K if you feel daring
    My bi xenons came from a 2007 S3 also, and the uprated bulbs are much better
    eBay is your best bet, i think the bulbs are D1S for mine, so should be the same for yours
  18. pi quattro
    pi quattro Member
    127
    cheers, didnt know that!
    Adaptive xenons are the one that turn with the wheels?
    are mine called Bi xenons or is there a difference between xenons and bi xenons?
  19. smudge_don
    2,944
    3 types of xenon from Audi:
    1) Xenon headlights - the dipped beam is xenon, the full beam is regular halogen bulb
    2) Bi-xenon - both dipped beam and full beam are xenon
    3) Adaptive bi-xenon - both dipped and full beam are xenon, and the lights move as you turn the steering wheel
  20. NHN
    29,331
    1,716
    You just dont have what is needed then son :p
  21. smudge_don
    2,944
    If i can't even replace the RNSE how do you expect me to read minds across thousands of miles?
  22. NHN
    29,331
    1,716
    Easy, use the force
  23. estwing
    estwing Member
    55
    i have also found out today, well just, that when the headlights are switched off the main beam will not work at all.
    When i switch the lights on, only the passenger side main beam works. There is a local audi,bmw etc serivce centre, is it worth taking the car there to get coded etc?
  24. NHN
    29,331
    1,716
    It needs rewiring properly along with coding & maybe other modules, where abouts are you as I do these jobs for people.
  25. estwing
    estwing Member
    55
    i am in sthelens, merseyside
    dont suppose that is anywere near you is it?
    also where is the fusebox for the windscreen wipers etc? i am useless at this stuff?
  26. NHN
    29,331
    1,716
    Anywhere is possible tbh, all comes down to time & money, this kinda job aint a quick fix usually, PM if interested.
  27. estwing
    estwing Member
    55
    pm sent :)
  28. thebott
    thebott Member
    211
    sounds like a nightmare , just drive in the day time only !
  29. estwing
    estwing Member
    55
    need these fixing before crimbo really, driving at night is a must !
  30. estwing
    estwing Member
    55
    right,
    i have been playing with the xenon headlights tonight while its been dark
    i have now noticed that they do spread abit of light over the road, i just think the bulbs are dim, like they are on there way out.
    so the question i have now is........... do you think they still need to be programmed for the car, or do you think i need new bulbs?
    the drivers side main beam does not work at all, and the passenger side main beam only works when the headlights are on. None of them work when the headlights are off (during the day)
    so what the problem, the wiring, the programming or the bulbs?
    please help!!!
  31. NHN
    29,331
    1,716
    No, they need programming, wiring & probably manually directing aswell which is what we've discussed to do for you iirc.
  32. Khufu
    5,704
    31
    I had a guy round a while back. He had fitted OEM Xenons and the were like disco lights LOL. I used VCDS to tell the car they are there & everything worked perfect - saved him driving back with fog lights on instead LOL.
    BTW, Nigel, whats the channel in the CE for Bi-xenon? I've got bog standard CE but it seems to have conflicting options for xenons. There is one for xenons and xenons (non shuttered) - Bi-xenon
    Surely shuttered are bi-xenon but my module doesnt support them??
  33. PH1L
    PH1L Gievf Buckets
    3,851
    40
    thats one of my biggest confusions atm too i think its the reason why i cant get my adaptives to code
  34. Khufu
    5,704
    31
    I've been looking over the wiring for such things. Im sure the adaptives are wired different to bi-xenons as well as being a different leveling module.
  35. PH1L
    PH1L Gievf Buckets
    3,851
    40
    im not retroing adaptive im faclifting from 08 adaptives to 10 adaptives mate, wiring is the same afaik
    *goes and double checks*
  36. Khufu
    5,704
    31
    Ah, sorry. Thought you were just fitting addaptives. I will take a look in my travels at the difference - doesnt the MY10 have a completely new CE module system? Maybe the buggers have moved things a bit?
  37. estwing
    estwing Member
    55
    yes matey, i was just adding this info incase it was something else.
    i hope you can fit me in soon as i really want these sorting. I look forward to hearing from you
