Xenon Headlights - Have or have I not got them?
wigginer Jan 30, 2007
  1. wigginer
    wigginer Member
    425
    I went into my local 'stealer' a few days ago to talk finance on a new car.
    During the discussion they informed me that my car had Xenon Headlights which until now I was not aware of. Afterall, they were not in the basic package or in the options I ordered as new.
    How can I check it has Xenons or not?
  2. andyccr
    andyccr 2003 1.8T Sport Ebony Black A4 Cabriolet
    442
    Are they very bright, and when you turn the headlamps on do they take a little while to warm up ?? Also they should self level test when you first turn them on
  3. wigginer
    wigginer Member
    425
    Not sure I understand, but thanks for responding:
    Bright compared to what?
    Warm up time ... compared to what?
    Self-level test ... what's this all about? ... Do you get some feedback from the DIS or whatever?
    Hate to be an 'Arsehole' ... but any other info would be appreciated!
  4. rickparmar
    rickparmar Active Member
    2,323
    14
    when you put the lughts on, doesnt it take a few seconds to blink and a bright white light comes on ?
  5. bubstar
    bubstar Member
    550
    WOW! You had the car how long and you don't know if you've got a £750 factory option?!! ;)
    I guess if you really aren't sure then take a look at the light switch, it won't have any adjustment buttons on it if you've got Xenons. Also you will have headlamp washers too.
    The lights will perform a self level check when you first turn on the ignition, even if they're switched off. When it's dark turn the headlamps on and then turn the ignition off when you turn the ignition back on the lights will cycle once - up, down and then level.
    Here's a pic' of my left Xenon, note the side lamp bulb is a H6W and not the normal W5W or 501.
    HTH
    BUB :beerchug:
  6. bubstar
    bubstar Member
    550
    It's more like a bright 'flash' and 1-2 seconds to reach full brightness.
  7. wigginer
    wigginer Member
    425
    Guys, From what you have described I have definitely not got Xenons ... the dealership must be having a bad day! ... one of many !!!
    When I switch my lights on they come on instantly and I have a little switch thingy for adjusting range to the left of my steering wheel.
  8. jonmusicman
    jonmusicman Member
    176
    An easier way of checking that everyone missed is... Have you got headlamp wash fitted?
    All cars with factory fitted with xenons must, by law, have headlamp wash. So my Audi dealer told me.
  9. Hotscar
    Hotscar Four Wheel Drifting
    562
    As said here but seeing as you have manual headlamp adjust, you haven't got Xenon's!
  10. Aldo
    Aldo Active Member
    1,017
    12
    Why does your Xenon unit look orange?
  11. wigginer
    wigginer Member
    425
    Thank God, that I've got that sorted I was beginning to get a bit paranoid, having not ordered them in the first place and the dealer turning up with mis-information ... I'll get my coat!
  12. LandSpeed
    LandSpeed Member
    229
    are the main/high beam still H7's on the xenons? as i want to change mine.
    (have you got any in that pic bub......cant see any)
  13. LandSpeed
    LandSpeed Member
    229
    id say it was the reflection from his indicator
    :thumbsup:
  14. Marko
    Marko Member
    202
    I'm a bit lost with this. My headlights look identical to Bubs but, I don't have any washer jets!! The reflection from a light surface has a blue tinge at the top. This can be seen when looking into the lights from a distance from the car and low down. I thought only Xenons had blue tints. ??
  15. Aldo
    Aldo Active Member
    1,017
    12
    They might be just Halogen projection lights, you can be sure if you have factory fit Xenons as per previously mentioned washer jets and when you first turn on the lights they are a crisp blue turning to a white light. :)
  16. Aldo
    Aldo Active Member
    1,017
    12
    Oh aye, I guess, trick photography :p
  17. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    when driving at night you'd soon know if they were xenons or not...!
  18. bubstar
    bubstar Member
    550
    It does look strange but just a reflection through the projector lens I guess.......
  19. bubstar
    bubstar Member
    550
    Yes the mains are H7's. I think the bulbs were still standard when that pic was taken. I'm using Osram Silverstars now which are very good but I fancy some of the new Philips X-tremes + 80% and E marked too :)
    BUB :beerchug:
  20. LandSpeed
    LandSpeed Member
    229
    what H6W's do you use bub ?
    Im defo going to get the x-tremes for my H7's
  21. bubstar
    bubstar Member
    550
    Philips Blue Vision. Not as good as LED's (Obviously) but much better than stock. I parked next to an S4 at a meet a while back and the owner commented how yellow his side lamps looked compared to mine.
    BUB :)
  22. LandSpeed
    LandSpeed Member
    229
    Thanks bub
    :beerchug:
  23. nivagh
    nivagh Member
    196
    Here's a related question...
    It's a real benefit to drive a car with bright headlights, but does everybody else get really p1ssed off with extremely bright lights at night. Typically X5s, Cayennes, TVRs and cars with heavy loads in the back who haven't changed the angle of their lights, or garages that haven't checked / adjusted the lights at MOT or service?
    The latest craze up here seems to be driving lights and fog lights. Not cool. Just irritating.
    I guess that, rather like illegal number plates, the police either have better things to do or too much paperwork to do to pull over idiots with defective lights.
    Personally I reckon the police ought to pull anybody with defective lights or mis-spaced number plates as a matter of course, as those are the vehicles most likely to have dangerous faults, no tax, insurance or undeclared modifications. In short, those people whose vehicles shouldn't be on the road.
    Ahh. Rant over. I feel better already. :)
  24. shineydave
    shineydave Member
    920
    indeed.
    as far as i can see the only purpose of fog lights these days is to warn other motorists that the driver of the offending vehicle is too stupid to operate a light switch
  25. wigginer
    wigginer Member
    425
    Nice one ... lol
  26. Caesium
    4,879
    Or... to illuminate the road and kerb in fog.
