Xenon headlamp retrofit problems
SinghB7 Jul 29, 2013
  1. SinghB7
    SinghB7 Active Member
    512
    67
    I've fitted the oem headlamps and installes the kufatec loom all correctly.
    now when coding with vagcom im changing the code from halos to bi xenon but when it's selected and click do it and go back to the last menu, the code don't save. I go back on to the headlight coding and its stays as my old halo headlamp code.
    any one shed any light on this as i'm driving to holland in 2 days and need it sorting
    thank you
  2. SinghB7
    512
    67
    Any one? Really need some help on this.
  3. psychopomp1
    psychopomp1 Member
    158
    14
    Not sure if this has anything to do with it but I take it you got a new central electrics module fitted? Because the existing CEM won't operate the bi xenons (at least on the poverty spec SE)
  4. SinghB7
    512
    67
    I havn't no, mine is a s line
    the xenons fire up but either one will go off after
    just the codes on vcds arn't saving when I change them for halogen to bi xenon
  5. SinghB7
    512
    67
    Bump
