Xenon dipped beam - down, switch off, normal again??
JD09 Feb 24, 2010
  1. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Noticed on the way home from the gym last night that my driver's side Xenon was basically pointed at the ground. Passenger side was fine.
    Got home, turned the car off. Same.
    Moved the car to face it at the garage to reallign (following threads on here about VAG COM useage and realigning the headlights) and it rectified itself.
    Obviously doesn't bother me now it's OK again, but would be interested to know if this is a known fault that I can proactively sort?
    Cheers for any pointers,
    James
  2. JD09
    3,096
    46
    Oh and car has been on level ground while at the gym and driving home (i.e. no hills etc).
  3. The Challinor
    The Challinor Well-Known Member Audi S3
    4,336
    1,107
    I think mine do a similar thing, sometimes i think my light are amazing and other they seem really aimed at the floor. In previous car's I've had had a manual adjustment for height but my obviously S3's ain't got that.
  4. Y83OLK
    Y83OLK Hulk Smash!
    841
    it does have manulal adjustment..
  5. JD09
    3,096
    46
    Behind the headlamp, Callum, yeah. But think he was talking about internal adjustment.
  6. The Challinor
    4,336
    1,107
    Yer I was on about internal, but how can I adjust it. I'd like mine a bit higher.
  7. JD09
    3,096
    46
    If you look at the back of the headlight unit (so bonnet open/up) there is a white plastic "bolt" that fits an allen key, not sure on the size however. If you turn this clockwise and anticlockwise it will adjust the lights up and down.
    However, you need to use VAG COM as other wise it will through up a fault saying the adjusters (presuming you have xenons) aren't in line or something. You need to adjust it with VAG COM as well.
  8. The Challinor
    4,336
    1,107
    Yer i have Xenons, think they came on all S3's as standard. Nothing is ever simple, lol my last 3 cars just had a nice little switch by the light to adjust. Looks like I'll be leaving that, was checked in the MOT so it legal height, I'd just like it a bit higher.
  9. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Mine does it every now and then.
  10. jdas03
    jdas03 Member
    603
    Mines the same except permenantly like it... i have been told that water may have go in and rusted it as the adjusters aren't working :-(
    Dont want to fork out for new lights so im just going to leave it until MOT time!
  11. The Challinor
    4,336
    1,107
    Looks like a common issue, A3 and S3 seems to have a few of these. Mine-due all car's have, considering mine is 10-11 years old its pretty reliable.
